How much peak boost can the stock turbo handle?
01-12-2018, 12:01 PM | #1 |
BMW Portland
224
Rep 524
I have searched around for this answer but unfortunately I cannot find the answer I am looking for. WITH supporting mods (Intake, charge pipe, cat-less DP, 7" intercooler) what is the peak boost that the stock turbo can handle? As in, not how much peak boost it can create, but at what PSI level does the peak boost put an overly excessive wear on the stock turbo?
Thanks! |
01-12-2018, 02:01 PM | #3 |
78
Rep 239
Are there any weakpoints aside from stock CP? I got a upgraded cp and fmic. but the fmic intercooler I have has the OEM style c clip mounts. Perhaps those are the week points for my particular setup? Also I still have the plastic "j' pipe between CP and fmic on driver side.
2011 335i M-Sport E92
MHD E30 | Phoenix Racing CP | K&N Drop In Air Filter |Fuel-it Stage 2 LPFP | xHP Stage 3 | VRSF DP | ARM 5" FMIC + Hose Upgrades | GFB DV+ | VMR 19" v703 |
01-12-2018, 05:50 PM | #4 |
BMW Portland
224
Rep 524
Thats good to hear. I am running just over 21 psi peak that tapers to 11.5 on 92 octane. This car is my daily and while a PS2 upgrade is in the future, I want to work on chassis/suspension mods before then. Just want to make sure the stock turbo wont go out on me anytime soon under that kind of peak boost.
01-12-2018, 06:27 PM | #5 | |
1161
Rep 3,189
Pladi718.00 |
01-12-2018, 07:40 PM | #6 | |
1161
Rep 3,189
01-12-2018, 08:30 PM | #7 |
396
Rep 1,210
I have only ever seen 23 psi but that is only for 500 - 1,000 rpms. Boost at redline is usually 11 - 13 psi.
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD 2019 Audi TT RS | 10.5@130 SOLD 2020 F97 X3M | 11.0@123 2023 G80 M3 xDrive |
01-13-2018, 08:45 AM | #8 |
BMW Portland
224
Rep 524
01-13-2018, 02:31 PM | #9 |
396
Rep 1,210
Get a N20 TMAP sensor. I have seen 23 on more than one setup.
01-13-2018, 03:59 PM | #10 |
BMW Portland
224
Rep 524
01-13-2018, 04:11 PM | #11 |
396
Rep 1,210
Your sensor is limited to 21 psi so it cannot effectively see boost higher than 21psi. For people that truly want to max out the stock turbo you should get this sensor. Most people are fine targeting 20 psi.
01-13-2018, 04:40 PM | #12 |
BMW Portland
224
Rep 524
03-19-2019, 11:13 PM | #13 | |
10
Rep 37
I have a 2019 X5 50i that I believe they increased the boost from 15 to 20psi. Dyno said 545awhp so about 150 awhp gain. My question is can I turn up the boost more? To what level? Will I need anything i.e. special fuel or other mods? Lastly, could this tune just have increased my boost and charged me $3k?? Thanks a lot! |
03-19-2019, 11:29 PM | #14 | |
1161
Rep 3,189
03-20-2019, 08:10 AM | #15 |
164
Rep 411
03-20-2019, 08:44 AM | #17 |
45
Rep 149
Re-pinning stock map sensor type "A" harness.
https://www.e90post.com/forums/showthread.php?t=1368216
2011 335I, E90, AT, Sport Package, FBO, Eibach 1" Lowering Kit w/ Koni Orange. MHD, 88k miles 2nd owner - Sold
2003 330XI, MT, bone stock, 160k miles - Sold 1988 325I Coupe, MT - Retired, 280k miles - Sold 2019 X7 XDRIVE 40I - Wife's |
03-20-2019, 09:10 AM | #18 |
70
Rep 491
Are these high numbers targets or actual boost?
How in the world are you getting such high numbers? I run MHD stage 2 and thought i would hit at least 14 but i target 14 and hit like 11
2011 N55 e92 Msport -Alpine White AT MHD Stage 2+, ARM 5" stepped I/C, PPK (coded over), Cobb charge pipe, gutted Xi downpipe, BMS intake, ARM I/C hose upgrade, PE mod, ST coilovers, 18x9 Apex ARC8 |
03-20-2019, 10:06 AM | #19 |
42
Rep 412
I would think you must have a boost leak somwhere, if you cant even hit 14psi. do you have any logs? is your PWM maxed out when making 11psi?
03-20-2019, 12:14 PM | #20 | |
718
Rep 1,753
People keep talking about boost.. old news guys |
03-20-2019, 01:03 PM | #21 | |
396
Rep 1,210
03-20-2019, 01:04 PM | #22 | |
1207
Rep 2,026
That doesn't mean much though when you can only do it for 500rpm lol. |
