01-11-2018, 03:05 AM | #1 |
196
Rep 283
*KLONK* rattle sound EIbach Pro Kit?
I fitted the eibach pro kit with a mechanic. since then i get these klonk rattle sounds when i go over bumps on the road. i think i had this sound also before the pro kit. Is this normal ? anyone else have this?
01-11-2018, 08:28 AM | #2 |
Meh
926
Rep 781
Drives: M3CS & Cayman S
not normal. check that the bump stops are seated correctly.
01-11-2018, 08:35 AM | #3 |
82
Rep 156
I have Eibach pro kit and do not have this sound occurring.
F87 M2 | DCT '17
E46 M3 |SMG '06 E46 M3 | SMG '03 E30 320iS | '90 E28 M535i | '84 |
01-11-2018, 11:36 AM | #4 |
71
Rep 105
Alot of people have had this problem.......including myself. Its an annoying sound
The solution for me was the bolt holding the strut to the lower mount (also has a bracket that holds the cables to the brakes) This bolt should not be over tightened. It needs to be loosened to about 25lbtft with a torque wrench |
01-11-2018, 11:57 AM | #5 |
196
Rep 283
hi! thanks for the reply. really? so its not the upper control arm or upper ball joint? its the strut? the first thing i thought that a screw or something is not tightened enough, but you say it had to be loosened. hmmm. But did you encounter this problem from the start with standard springs or only after eibach springs mounted? the strange sound i mean. Both strut in the back both sides has to be loosened or only one side? the front struts front axle you didnt bother with it right? just the rear?
01-13-2018, 10:08 AM | #6 | |
190
Rep 86
Unfortunately I've got the same problem with my car when crossing small bumps. |
01-13-2018, 10:37 AM | #7 |
391
Rep 960
In all my older cars that were lowered when Ive had this noise it was one of 2 things... bolts not tight or 2 strut mount bearings needed to be replaced. Not sure if that helps but just trying to be helpful.
01-31-2018, 08:15 PM | #8 |
1095
Rep 1,261
Drives: 20 BMW M2C 17 Mazda MX-5 RF
Check your top strut nut. Very common for it to back off. Use locktite to keep it secure...
HTH
2005-2006 BMWCCA Boston Chapter president
2004 Mazda Rev It Up Finalist 2002-Present HPDE Instructor My 2020M2C Build: https://f87.bimmerpost.com/forums/sh....php?t=1696726 |
03-20-2018, 09:31 PM | #10 |
27
Rep 46
Anybody find the solution for this?
I just installed the macht schnell springs and have a noise like this on the driver side front. It only happens when going slow and hitting sharp bumps. |
03-21-2018, 08:47 AM | #11 |
1836
Rep 4,204
That sounds like a strut nut or swing arm link not torqued. Hopefully who ever did the install torqued the lower strut cradle correctly
