F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Paddle Shifter Retrofit
ARMA SPEED
      01-09-2018, 03:38 PM   #1
Nd0udoinwork
Drives: Red 328i XDrive
Can you add paddle shifters to the base sport steering wheel, as in not the m-sport wheel. Because i like the normal wheel but want to add paddles. What parts would i need?
      01-10-2018, 06:56 AM   #2
ChubbyWilly
ChubbyWilly's Avatar
Drives: 2015 BMW 335i
There's plenty of DYI's on this you just have to search for them.
But, I did this to my own car just last week and I've attached the PDF I used. One thing I lucked out on is that my car is pre-wired for the paddles.
File Type: pdf DIY Paddle Shifters BMW F30 Rev. 3L.pdf (5.35 MB, 23787 views)
Mods: MHD Stage 2+ FlexFuel, xHP Stage 3, VRSF 5" HD Intercooler, VRSF Charge Pipe, CircuitWerks Catless DP, AFE Pro Dry S Intake filter, Eldor coils, NGK 97506 @ .026, Bilstein B14 coils.
Appreciate 2
      01-14-2018, 02:45 PM   #3
UtilisaE9
Belgium
13
Drives: Various BMW
Nice!
Is this DIY applicable for the M Sport Steering wheel?
Thx
      01-15-2018, 12:30 PM   #4
ChubbyWilly
Originally Posted by UtilisaE9 View Post
Nice!
Thx
I believe the M Sport steering wheel just needs the different backplate piece and may require you to drill into it, but yes this DIY will work with the M Sport steering wheel.
      01-15-2018, 03:15 PM   #5
zole2112
Modder of everything I own
zole2112's Avatar
147
Drives: 2013 335i Xdrive
I added paddle shifting to my 2013 335i this past summer. I was going to modify my Sport Leather steering wheel but I was concerned about cutting the paddle openings in the back of the steering wheel so I ended up buying a Sport Leather steering wheel with paddles. My car was prewired from the steering wheel to the FEM module, you can verify if yours is or not by checking the plugs in the steering wheel and the FEM module. If there is a wire with pin in plug A83*2b in position #3 in the steering wheel and a wire with pin in plug A173*7b in position #5 in the FEM module then it is prewired. You would still need the paddle harness BMW part #32306854769 to connect the paddles.
Of course you still would need to code it for paddles with ESys
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
      01-15-2018, 03:30 PM   #6
zole2112
zole2112's Avatar
147
Here are couple pics of the paddle cutout and the harness end and paddle mounting screw. The issue I saw was getting the proper depth for the paddle, i figured I could cut it all the way to the metal spoke and add filler to get the depth correct.
      01-19-2018, 04:26 PM   #7
omglol
Drives: F31
Guys, could anyone measure resistance of +/- paddless? I am having problems with mine and I am waiting for monhts for someone to help me with measuremens. Thanks.
      01-22-2018, 07:18 AM   #8
Kailec
Kailec's Avatar
595
Drives: 2013 328i xDrive
Hey there, you're still having this issue?
From this thread:
http://f10.5post.com/forums/showthread.php?t=1274977
Here are the values:
F30 Down / - Paddle
Open/OFF 6.55kΩ
Closed/ON 349Ω
F30 UP / + Paddle
Open/OFF 6.17kΩ
Closed/ON 1.180kΩ
Now the question is if you're comfortable soldering resistors to alter them if they're not correct on your paddles. I was lucky because my seller just sent me a new paddle circuit and so it all worked out. Hope this helps.
omglol0.00
      02-01-2018, 03:26 PM   #9
omglol
Drives: F31
From this thread:
F30 Down / - Paddle
Open/OFF 6.55kΩ
Closed/ON 349Ω
F30 UP / + Paddle
Open/OFF 6.17kΩ
Closed/ON 1.180kΩ
Oh my god, thank you so much! Yes, I am totally familiar with soldering ... in fact, I do it as a part of my job (electrical engineer).
      02-01-2018, 06:28 PM   #10
Kailec
Kailec's Avatar
595
Good luck! Hopefully that's accurate though, as I'm just reposting information someone else got.
      02-06-2018, 02:51 PM   #11
omglol
Drives: F31
I solved my problem today.
Some bastard on eBay sold me (-) paddle for F10 and (+) paddle for F30 ... so I only had to change resistors on (-) paddle. Paddles between F10 and F30 differ not only in resistances, but also on PCB layout, so you need to solder new resistors on different locations ... but you can figure it out with a multimeter very simple and it does not require any modifications.
      02-06-2018, 02:58 PM   #12
bimmer456
2966
Drives: 340i
May have been addressed but the sport line models have the regular steering wheel with paddles. You can simply swap for one of those. You then have to code something like 2TB for sport automatic transmission which uses the paddles and is also a sportier and more aggressive shift in sport mode in general.
      02-06-2018, 05:05 PM   #13
Kailec
Kailec's Avatar
595
Were the values accurate though? Great that you finally resolved it after so long! I know you said simple but I would have no clue on what to do.. Lol
      02-07-2018, 02:47 AM   #14
omglol
Drives: F31
Yes, I actually ordered same values as the resistors in the picture. Everything was spot on, including old resistor values.
      02-07-2018, 05:51 AM   #15
Kailec
Kailec's Avatar
595
Sweet, good to hear! About time you finally sorted it out.
omglol0.00
      02-08-2018, 07:42 PM   #16
arom
arom's Avatar
Drives: 2016 320i xdrive
Is there anyway you can tell which paddle comes from an F10 and which comes from an F30? Is there a part number on the paddle to check??
      02-27-2018, 04:26 PM   #17
omglol
Drives: F31
See link in post #8. They are only different internally, there are no part numbers on them.
      02-27-2018, 05:11 PM   #18
Kailec
Kailec's Avatar
595
I don't think it really matters. At the end of the day they're all functionally the same, it's switch that turns on and off. The paddles themselves only send an electric current to another module that interprets that to shift up or down. Probably the only difference is the resistance that is different between an F10 and F30.
      03-02-2018, 03:04 PM   #19
m_paltik
Drives: F30 328i
Hello everyone! I'm sorry I'm new to posting in forums but have been around reading all types of thread. I'm hoping someone could help me out.
A few days ago I was replacing my base steering wheel to a Luxury Line Steering with paddle shift. I didn't have the wire from FEM to SZL so I followed the instruction here on the forum and also watched Brian (Kies Motorsports). I disconnected the battery and began removing the airbag. Removal and installation is finished and I connected the negative battery terminal. The moment of truth, I push the Start button (No Engine Start) and the wiper started moving. I thought maybe I hit the switch. I tried turning it off but it won't turn off. Pretty much all the SZL isn't working (turn signal, wiper, steering control, horn, lights on the steering control).
I did some reading and bought a used SZL from eBay thinking my SZL was bad. It is from a 2015 F32 335i. It's the same exact module. I just installed it earlier and everything is the same. I'm still having the same problem. I have no idea what went wrong.
My car is a 2013 328i Base Model. I wouldn't be able to take the car to the dealer not until Tuesday next week on my day off. I don't want to take to the dealer if I could fix it myself. I hope anyone can chime in what they think is wrong. Thank you!
      05-05-2018, 05:13 PM   #20
turbo63
Drives: 2014 328i
You ever able to figure this out? Cause I did the exact same thing right now and am in my garage freaking out.
I even put my old wheel back on at the same problem.
      05-06-2018, 04:05 AM   #21
m_paltik
Drives: F30 328i
I took it to a BMW indie shop. He re-programmed the SZL and that fixed it.
      05-06-2018, 12:29 PM   #22
MoeRahman
Drives: BMW 328i xDrive 2013
Anyone know the parts needed for the 2013 328i xdrive in order to retrofit the paddle shifters?
f30post
