Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > N55- Valve Cover Removal
      01-09-2018, 07:24 AM   #1
CobraMarty
CobraMarty's Avatar
619
Drives: 2007 328xi e90 + e92
How long does it take to remove the N55 valve cover?
How hard is it to remove it?
      01-09-2018, 07:43 AM   #2
orteeze
223
Drives: 2018 YMB F80
It's a pretty straight forward job if you ask me. The most difficult part is clearing the firewall on removal. It has a weird lip that causes clearance issues. Second set of hands would make the job easier.
2008 MB 335i-SOLD
2011 AW 335i M Sport- SOLD
2011 BSP 335i-SOLD
2011 BSP 335is- FOR SALE
2018 YMB M3- Current
      01-09-2018, 07:50 AM   #3
weehe126
1161
Drives: 2017 340i
R&R I can do it in 3-4 hours depending if the firewall agrees with me that day.
      01-09-2018, 07:54 AM   #4
Wolf 335
Wolf 335's Avatar
2341
Drives: 2007 E92 335i
Side question: Do N55 covers crack like the N54 ones?
      01-09-2018, 08:53 AM   #5
weehe126
1161
Drives: 2017 340i
Not as regular as N54, but the PCV valve inside is not serviceable and goes bad every 60-80k miles.
      01-09-2018, 08:54 AM   #6
Wolf 335
Wolf 335's Avatar
2341
goes bad as in gets clogged with oil sludge?
      01-09-2018, 08:59 AM   #7
CobraMarty
CobraMarty's Avatar
619
Do you have to pull the DI fuel lines and common rail?
      01-09-2018, 09:05 AM   #8
RoarinForeign
Drives: 2011 e92 335i xdrive
Am currently in the process of changing my valve cover gasket and spark plugs/coils.
      01-09-2018, 09:16 AM   #9
CobraMarty
CobraMarty's Avatar
619
I'm asking the time and difficulty for the VC R+R as it would be required to install a set of MILVs in place.
MILVs on a N55 would be awesome.
      01-09-2018, 10:33 AM   #10
WiL335i
Drives: 2011 335i Coupe Alpine White
I just recently performed this job by myself. It's not that difficult. It's basically the same thing as any other cars with the exception of the additional steps of removing the fuel lines that goes over the top of the valve cover because it's a direct injected engine. I believe there's a DIY thread here with step by step instructions and pictures. I suggest you read that thread. Somebody mentioned that the PCV valve is not serviceable and goes bad at around 80k miles, that is correct.
I also bought the Uro brand valve cover and not the expensive BMW brand. I closely inspected the two and it looks exactly the same. It fits perfectly and I encountered no problems during the Installation. I saved over $200 on it.
      01-09-2018, 11:46 AM   #11
weehe126
1161
Drives: 2017 340i
One of the flaps rips causing excess crankcase vacuum.
      01-09-2018, 11:47 AM   #12
weehe126
1161
Drives: 2017 340i
Just the injector hard lines, the rail can stay.
      01-09-2018, 12:34 PM   #13
Pladi
Pladi's Avatar
718
Drives: 2011 335i xdrive
Thanks for the reply. Do you have to remove the injectors ? I recently replaced my injectors and would not like to remove them if i dont have to due to the teflon seals that have to be replaced.
      01-09-2018, 01:36 PM   #14
AJL
AJL's Avatar
Drives: 2011 335i M Sport
No, don't need to remove the injectors.
https://www.newtis.info/tisv2/a/en/e...h-lid/CsT0IDpE
2011 335i E90 - VRSF Downpipe & 7" FMIC | MHD 2+ | DCT
      01-09-2018, 01:36 PM   #15
weehe126
1161
Drives: 2017 340i
Don't need to remove injectors.
      01-09-2018, 03:11 PM   #16
Pladi
Pladi's Avatar
718
good to know thank you guys.
      01-10-2018, 09:48 AM   #17
Welcome to NBA Jam
Is it the shoes!?
Welcome to NBA Jam's Avatar
3884
Drives: (Sold) 2011 E92 335i ZMP 6MT
Good news is there is a solution for it as long as you have a dremel. You basically cut the top off, replace it, and glue it back on.
https://vanos-bmw.com/product/repair...mw-11127570292
feuer4275.50
      01-10-2018, 12:19 PM   #18
weehe126
1161
Drives: 2017 340i
You can only access 1 of the 3 or 4 valves. And no one has been successful in doing it, or no one that I've heard.
      01-10-2018, 03:47 PM   #19
Pladi
Pladi's Avatar
718
Can someone please tell us how to test the PCV exactly because that site mentions blowing into something but i am not sure where.. is the engine ON/OFF.. other details. A detailed explanation would be very useful. So we dont replace parts that dont need to be replaced or can see if a valve is on its way.
      01-10-2018, 04:32 PM   #20
weehe126
1161
Drives: 2017 340i
It's in the DIY section by user Vespa.
      01-10-2018, 09:42 PM   #21
Pladi
Pladi's Avatar
718
So here is the thing. These cars have a billion sensors sometimes for even useless stuff like brake pad wear that i can see with my eyes but no one thought it would be a good idea to measure that vacuume/pressure of the ventilation system ?? I have to use smoke from a match or a cigarette to test a pcv system ? Now i understand we can measure vacuum but the PCV valve air is not measured...why
      03-24-2019, 05:34 PM   #22
Scuttles
Drives: F30 335i
I've spent a few hours this weekend looking this up -- and have not seen a single case of someone failing at this... can you explain?
