01-05-2018, 07:56 AM | #2 |
82
Rep 156
Yes, I use it.
Works perfectly. Here is a list of what I have done. Disabled Auto Stop/Start being enabled by default Lights under door handles illuminate on reverse Warning sounds changed to BMW i Turned off bulb monitoring on the rear light clusters due to fitting LED bulbs Video In Motion Video codecs And a few others I cant remember. Well worth the money and a lot easier than messing about with E-Sys!!
F87 M2 | DCT '17
E46 M3 |SMG '06 E46 M3 | SMG '03 E30 320iS | '90 E28 M535i | '84 |
01-05-2018, 08:20 AM | #3 | |
42
Rep 137
I very much like the idea of stopping start stop! Ha With my Audi it (Carista was the app for that) would kill the feature completely. Does BMW start / stop still work if you press the button after modifying with Bimmercode? Also, how do BMW see tweaks like this from a warranty standpoint? I think with Audi it was a bit questionable, I imagine this is much the same. Can you take a somewhat 'backup' of the entire config before messing? Or is that with e-sys only? Thanks! |
01-06-2018, 06:57 AM | #4 | |
82
Rep 156
Not so sure about warranty issues, after all, your not changing anything permanently, can easily be put back. Bimmercode app automatically backs up the cars config before coding. This is stored on the device running Bimmercode, in my case, thats my iPad.
F87 M2 | DCT '17
01-06-2018, 06:06 PM | #5 | |
42
Rep 137
01-06-2018, 07:29 PM | #6 | |
82
Rep 156
Bimmercode is easy to use and is well priced. I highly recommend it.
F87 M2 | DCT '17
azibux142.00 |
01-08-2018, 03:41 PM | #7 |
42
Rep 137
01-09-2018, 11:29 PM | #8 |
42
Rep 137
DoZZa do you really need the below as their website states??
https://www.amazon.com/Vgate-Scanner...15715fc91727ce With Carista you could use any bluetooth or wifi adapter that was suitable for ELM327 v1.4. Obviously I understand if this app only works with wifi, but still any wifi OBD should do the job surely? Or do I actually need the Vgate? Reason being I already have a generic wifi one, so don't want to buy another - but also don't want to subscribe to the app to find the one I have won't work lol |
01-10-2018, 06:12 AM | #9 | |
82
Rep 156
https://www.amazon.co.uk/gp/product/B01CG0XWDI I have no idea if a generic Wi-Fi OBD adapter will work with BimmerCode app. Perhaps ask the developer. He can be contacted here info@bimmercodeapp.com
F87 M2 | DCT '17
01-10-2018, 10:41 AM | #10 | |
42
Rep 137
01-13-2018, 01:07 PM | #12 |
42
Rep 137
EDIT: Working perfectly, I missed the actual "code" button... Great and quick response from Stephan at BimmerCode! ######## I got this all earlier (app and VGate). Made a change just before going out. Changed start stop to disabled by default. Then exited the app. It hasn't worked though. Engine was on while I was coding as I'd read here about people saying the ignition could switch off if the engine isn't started. Any ideas why it didn't work? Do you have to 'apply' anything? Or just click the option you want? Will try again later otherwise Thanks Last edited by azibux1; 01-13-2018 at 06:21 PM.. |
01-14-2018, 04:13 PM | #13 | |
Rep 19
Very easy to use once you get used to it and I like the fact you can return to default settings if needed. |
01-15-2018, 01:10 PM | #14 | |
42
Rep 137
Yeah it's a brilliant app! |
