Help!! 29DD and 2C58
01-01-2018, 03:58 PM | #1 |
20
Rep 49
Hi guys,
I have recently been having cold start issues with my '11 n55. When the car has been sitting overnight and I go to start it in the morning, it almost immediately dies (rpms go down to ~500), it struggles, then finally surges back to life and the idle fumbles around for a bit. Warm starts are not an issue. Driving feels relatively normal. I have also noticed an increase in fuel consumption. Finally threw 2 codes at me: 29DD - Charge air temperature sensor, plausibility, cold start: temperature too low 2C58 - Charging pressure control, deactivation, pressure build-up blocked. Any insight? Thanks in advance. |
01-01-2018, 11:08 PM | #3 | |
20
Rep 49
I will look into those items. Do you think there is a chance it's the charge air temperature sensor? |
01-03-2018, 09:39 AM | #4 |
20
Rep 49
UPDATE:
Scanned again and in addition to the 2 active codes posted above - there are 3 Shadow (inactive) codes: 2904 - Charge-air temperature sensor: Multiple Fault 2908 - Charge-air temperature sensor: Multiple Fault 29E6 - Charge-air temperature sensor, cold start: Multiple Fault Mods are MHD stage 1, Cobb chargepipe, BMS intake. |
07-07-2020, 08:47 PM | #5 |
Rep 31
Evening All
I wanted to reach out to this thread, if there was a solution. A few days ago I added 5 gallons of e85 fuel (as always) to my car 2011/FBO/PPK Flash/Alpina Tune/JB4 Map 5 and recieved the following codes with an engine malfuction! 29DD 2C58 I thought it was the JB4 not adjusting to the higher fuel so I cleared the codes and switch to Map 0 from Map5 and back. The car was running great for the past couple days and then today I went to start the car (cold sart) and recieved the same message and codes. Was there a resolution to this? replacing the boost solenoid and vaccuum lines, I also read somewhere that it might be a Vanos.. |
07-09-2020, 02:54 AM | #6 | |
Member
41
Rep 102
12' 335i xDrive
Pure Stage 2 11.4s@120mph (Full Weight + 50lb ea wheel on street) // E30 Wedge Performance |
07-25-2020, 10:47 PM | #7 | |
Rep 31
hope this helps! |
