12-29-2017, 10:47 AM | #1 |
19
Rep 124
Restraint system failure
I need some help guys. I've been doing a lot of coding lately. I retrofitted the M Performance Brakes. I retrofitted HBA / FLA and everything was okay until after the HBA / FLA retrofit.
Basically after the HBA / FLA retrofit I default coded each ECU to make sure everything was coded how it should. After that, I keep getting a Restraint system failure message on my Head Unit. I tried default code the ACSM module. I've tried External Applications > External Application > Transmitter > ...Clear all DTCs... I have also tried Tool32 > F01.PRG > FS_LOESCHEN_FUNKTIONAL But nothing is working. Only thing I can think of is changing VO options. Here's all the differences: E-Wort: A090 LEDE HO-Wort: SPBR ( SPBR_18_ZOLL_SPORTBRAKE ) [Added] SALAPA-Element: 1CA 1CB 216 248 249 258 2NH ( M Sport brakes ) [Added] 2PP 2VB 302 319 337 3AG 403 423 430 431 459 465 481 493 494 496 4DX 4MR 4NE 502 507 521 522 524 534 544 563 575 5AC ( High-beam assistant ) [Added] 5DS 609 615 ( Expanded BMW Online Information ) [Removed] 616 ( BMW Online ) [Added] 645 676 693 697 6AA ( BMW TeleServices ) [Removed] 6AB 6AK ( Connected Drive Services ) [Added] 6AM 6AP 6NR 6NS 6UH 6VA 6WA 710 715 760 775 823 840 845 853 876 8KC 8S4 ( Decoding variable light distribution ) [Removed] 8TN 925 992 993 9AA Any ideas?? Last edited by ryantpayton; 12-29-2017 at 11:04 AM.. |
12-29-2017, 11:18 AM | #2 |
19
Rep 124
Okay pointless thread... Sorry about that.
I fixed it. But for anyone else on here with possibily similar issue: I changed my Zeitkriterium from 1112 to 1113. This was a long time ago so I forgot about it. I looked at a untouched VO from a car that was literally made a couple days after mine. So after changing back to 1112 it fixed my issue! Thanks anyways! |
