12-28-2017, 05:20 PM | #1 |
310
Rep 339
Corner balancing, to do or not to do?
Hey everyone. I'm looking to upgrading my suspension soon to Bilstein coilovers and haven't decided which camber plates yet. I was wondering, what would be the benefits of me having the car corner balanced after installation? Is this something I can skip without any negatives? My car will be mainly street driven with maybe a track day here and there. Even then, a track say may not be for a while. Thanks
instagram: @ sf87_m2
12-28-2017, 06:20 PM | #2 |
197
Rep 155
This is my impression: Nothing wrong with NOT corner balancing your car. Corner balancing is supposed to help your vehicle behave more consistently(better) when corner, braking, etc. An analogy I've used is imagine a 4 legged chair where 3 of the legs are the same length and the 4th is shorter. If you are a novice/intermediate driver, corner balancing your car will probably not lower your track times nor will you feel much of a difference(at least in my case).
Its definitely not a waste of time or money. Corner balancing will only be more beneficial to your vehicle, but dont let it stop you from driving around the streets or track! Again, this is only my perspective. YMMV
Living Life Turn After Turn!
[/url] F87 M2 Performance Edition - 2017-current F15 X5 35d - 2014-2017 E36 M3 - 2009-2016 |
12-29-2017, 08:59 PM | #3 | |
793
Rep 1,366
12-30-2017, 01:25 AM | #4 |
91
Rep 135
In my case, it was totally worth it - $300 which was not much compared to the cost of the coilovers. This was on a different car but if I put coilovers on my M2 I'd do the same thing.
I may not have needed the exact precision they gave me but it was easily worth having someone with deep knowledge of the subject area set up the suspension. The shop owner even interviewed me and set ride height, camber, toe, etc perfectly for what I wanted to do with the car. |
12-30-2017, 11:08 AM | #5 |
391
Rep 960
I didn’t corner balance. I did get an alignment tho free by bmw. and I also got -2 degree camber in rear. You ain’t tracking so ain’t a big deal.
Someone people on this forum is anal about these things. |
12-30-2017, 07:45 PM | #6 |
1330
Rep 2,214
Well worth it if
A) You have replaced enough components, wheels included, that would effectively alter the balance of the car. B) If you drive the car hard enough to warrant the fine tuning, itself. If you're simply installing a set of "pre-tuned" coilovers I'm not sure it's warranted, to be honest. Coilovers, Sway bars, Lightweight Wheels, suspension arms/bushings, absolutely 100% worthwhile. For those who are getting this done for under $500, that's a great deal!
01-02-2018, 11:55 AM | #7 |
116
Rep 306
Drives: MY17 LBB M2
If it is just a DD, all you need is an alignment. The M2 is already very well balanced and unless you are a heavy guy or tracking it, I wouldn't recommend.
But as others have said, it never hurts if you have the time and money for it (which are both pretty nominal for a quality corner balance). |
emdeuce196.50 |
01-02-2018, 12:39 PM | #8 |
310
Rep 339
Thank you everyone for all your helpful input. I think I'll just get alignment and skip the corner balancing for now and maybe get it in the future when I find a more permanent setup with suspension and wheels and if and when I have a future track day planned.
emdeuce196.50 |
