M2 Technical Topics > Suspension | Brakes | Chassis > Mperformance suspension, lower the rear
      12-28-2017, 12:32 PM   #1
Robban
267
Drives: M2
Hi All,
I have the Mperformance coilover suspension kit installed on my M2 and all settings are accordingly to BMW instructions.
The ride height is therefore;
Front: 595 mm
Rear: 600 mm
This is measured from the lower rim edge to the fender edge.
However I would like it to go just a bit lower in the rear, but the adjustment nut is in the max position (see picture)
My question is if someone removed the adjustment nut. Since its in the maximum setting, it doesn't make any sense. To remove would directly drop 5-8 mm on the rear, that would be perfect.
What do you think? and does anyone have the experience that made the same alternation.
BR
Robert
      12-28-2017, 12:59 PM   #2
wolfbane1967
93
Drives: BMW M2
I think you go a point here, might try this to
Robban267.00
      12-28-2017, 02:04 PM   #3
Ynos22
Drives: BMW M2 2017
Mine is 595mm rear with the Mperf.
Try to free the rear sway bar when the wheels are down the floor, if it is stuck in the silent bloc it may rise the rear of the car a bit.
      12-28-2017, 11:40 PM   #4
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
Give it a 100 miles if you have not already done so and measure again.
BTW, I'm on MPS too and I think it's just silly to control height that way. Should measure directly on coilover like other KW V3 kits.
Lemania 2320
      12-29-2017, 02:30 AM   #5
Robban
267
Drives: M2
Thank you for the feedback.
The MPS has been on my M2 for a year now so it's seattled as it should.
Agree with you how it's measured.
At this stage I am a bit puzzled how BMW could accept the height adjustments.
As the maximum distance equals the recommended setting....
Front is OK there is still approx 10 mm more to adjust.
      12-29-2017, 05:40 AM   #6
SeanWRT
SeanWRT's Avatar
3179
595/600mm is with 150kg passenger... So probably you're already lower than recommendation.
Plus, pay attention when measuring height. Need someone from distance to check and ensure that your ruler is vertical to ground. It's easily off you just can't see that from up close.
Lemania 2320
      12-29-2017, 08:01 AM   #7
Egress
47
Drives: M2
This plus a full fuel tank lowers the car about 2-3mm. So having 150kg in the car plus full tank surely will make your rear end sit at about 592mm which is already quite low...
      12-29-2017, 12:41 PM   #8
Robban
267
Drives: M2
Thank all for you information, however my question was more directed to the adjusting nut and the removal of this.
If there is anybody that has already made this action and the what was the end result.
      12-30-2017, 05:06 PM   #9
Aronis
Aronis's Avatar
2267
Drives: 2018 M5
Do you have photo of the car before and after (with wheels LOL)? Thanks.
Mike
2018 M5 and 2019 Porsche Boxster GTS
Prior. '94 325is, '97 M3 Lux, '16 M2
      12-31-2017, 01:42 AM   #10
Robban
267
Drives: M2
Mike
Unfortunately I only have with the MPS since it was installed prior the delivery by the dealer.
Here is the picture and my intension was to slightly lower the rear in addition. The main reason is that I will have 10,5" rims on rear.
Search this Thread:
Advanced Search
m2
