BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding G30 Screen Mirroring Always On Coding Possible?
      12-23-2017, 07:15 PM   #1
FadyDizzle
49
Drives: -
Hi all,
I've read a bit about coding and tried browsing some of the free software before buying the cable and messing around with my car (namely looking through BMW Coding Database) and I have a question on the availability of a feature...
I currently have in my 2017 G30 the screen mirroring feature on my android phone which works well but when the car is in park of course. There are times where my built in navigation absolutely sucks (whether inefficient routes or getting me to the wrong location) and for those times I'd like to just use Google Maps. Since Android Auto doesn't exist on BMW, I'm wondering if there's a coding feature that allows you to put screen mirroring in always on mode even while driving so I can use Google Maps Navigation those times I can't rely on the iDrive nav. Is that possible? If so, can someone point me in the right direction to find the instructions to code such a feature?
Thank you!
      12-24-2017, 09:58 AM   #2
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Video in motion.
      12-24-2017, 03:25 PM   #3
FadyDizzle
49
Drives: -
Originally Posted by Almaretto View Post
Video in motion.
Great, thank you, so I see for the F10 a Function Value "Video_Front_Locked" - I assume that's what I have to code (active by default, so deactivate it) in order to get the function to work as I'd like on my G30?
      12-24-2017, 04:48 PM   #4
Almaretto
Almaretto's Avatar
2374
Negative. You need Bimmercode or other commercial solution. E-sys can only unlock to 39 mph.
      12-29-2017, 10:02 AM   #5
FadyDizzle
49
Drives: -
Thanks, so I got a cable on ebay (Ethernet to ODBII) and I got Bimmercode on my phone but Bimmercode seems to want a specific adapter. Is there anything as user friendly as bimmercode seems to be that I can use from my computer using the ethernet to ODBII to do some basic coding (even if the only to 39 mph to try it out)?
I got a bunch of software from the instruction guide (E-sys, Psd, etc.) but not sure where to start. Any other guides on the forums you can point me to? Thanks.
      12-29-2017, 10:58 AM   #6
Almaretto
Almaretto's Avatar
2374
Coding: Getting Started Guides, Tips, & Cheat Sheets
You can use Launcher Cheat Codes and set to 39mph.
      12-31-2017, 01:02 PM   #7
mobilejo
mobilejo's Avatar
United Kingdom
1110
Drives: G06 X6 40i
The correct adapter for Bimmercode was very cheap on Amazon. And it worked perfectly to unlock VIM for me.
Having said that, it was the only thing that I found Bimmercode useful for, but for the VIM alone it was worth it.
      12-31-2017, 05:34 PM   #8
FadyDizzle
49
Drives: -
So to go the Bimmercode way (which seems simpler than the laptop and cable solution) all I need is the app and the below device? Might just go that route and return the cable I got...
https://www.amazon.com/Vgate-Elm327-...rds=bimmercode
      12-31-2017, 06:00 PM   #9
mobilejo
mobilejo's Avatar
United Kingdom
1110
Drives: G06 X6 40i
Correct. It's super simple
      01-13-2018, 10:19 AM   #10
FadyDizzle
49
Drives: -
Can someone tell me where the odb2 port is? I tried looking under the passenger side footwell area based on a YouTube video and I can't find the same port, I can only find the area to replace fuses. I'm wondering if the YouTube video was for a European model and it's different in the u.s. for some reason. Thanks
      01-13-2018, 01:35 PM   #11
Almaretto
Almaretto's Avatar
2374
It is on drivers side. Superior lateral wall of footwell space.
      01-13-2018, 04:16 PM   #12
FadyDizzle
49
Drives: -
Is it exposed or do I have to remove the cover?
      01-13-2018, 04:26 PM   #13
Almaretto
Almaretto's Avatar
2374
No cover.
View post on imgur.com
      01-13-2018, 04:34 PM   #14
FadyDizzle
49
Drives: -
Ok, thanks so much, those pics are so helpful.
      01-13-2018, 05:15 PM   #15
Almaretto
Almaretto's Avatar
2374
      01-13-2018, 07:55 PM   #16
FadyDizzle
49
Drives: -
Thanks again, everything looks like it worked out. Took some time to get it connected initially but once it connected, coded using BimmerCode (I had a ton of Google Play credit from Opinion Rewards app, so got to use that to unlock the coding feature). I did VIM, changed the ringtone, turned off the warning when you turn on the car.
That said, any other things anyone recommends trying out?
mobilejo1110.00
Search this Thread:
Advanced Search
5post
