2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Rear fog lights on without the headlamps?
      12-20-2017, 06:44 PM   #1
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
Recently coded in my rear fog lamps and did the button mod:
http://www.2addicts.com/forums/attac...4&d=1421099515
Anyone know if it's possible to code the rear fogs so they can be turned on by themselves, without the headlights turning on as well?
      12-20-2017, 07:53 PM   #2
delvec03
90
Drives: 228i Sport/ DSB
pretty sure that's what I have now. rears don't turn in headlights. only the fronts do
      12-21-2017, 02:01 PM   #3
AbuQutaita
Drives: 2018 BMW M240i
2018 BMW M240i  [0.00]
I’m pretty sure you can’t, and why would you want to do this anyway? If there aren’t low-visibility conditions, where you’d want your headlights on in the first place, the rear fog lights are annoying to drivers behind you.
      12-21-2017, 02:04 PM   #4
AndrewC1989
that's the idea. i use it as a "stop tailgating me" button. (i don't drive around with them on normally).
i was just curious if it was possible to turn them on without the headlights coming on. it turns out you can't. no big deal.
      09-26-2018, 06:03 PM   #5
mike185
mike185's Avatar
Drives: X3 X28i ; M235i xdrive Convert
Hi I live lodi nj and have a M235i convertible , I bought the rear fog light switch and need it coded to make them to work , you know anybody that does coding for a reasonable price ?
Please let me know Mike michele1070@gmail.com cell 2013762877
      09-26-2018, 06:06 PM   #6
AndrewC1989
Sent you a PM
      10-05-2018, 10:19 AM   #7
mburg
MBurg
mburg's Avatar
63
Drives: '22 230
I have a '19 230i
Two questions:
1. Does anyone have a more detailed guide about how to remove the AC vent/light switch?
2. Once the switch is modified, is it still necessary to code the switch to turn on the rear fog? If so, is there an easy way to do this with Bimmercode 'app'? (I guess 3 questions).
Thanks
      10-05-2018, 10:29 AM   #8
AndrewC1989
Originally Posted by mburg View Post
I have a '19 230i
Two questions:
Thanks
Rear Fog Light Mod For US Spec Cars
https://f87.bimmerpost.com/forums/sh....php?t=1450178
      10-05-2018, 11:06 AM   #9
mburg
MBurg
mburg's Avatar
63
Drives: '22 230
Thanks for this link.
Is there anything more specific about removal of AC vent to get at the light switch?
      10-05-2018, 11:07 AM   #10
AndrewC1989
You just pry it out with a trim tool. It's not held in place by anything.
      10-05-2018, 11:11 AM   #11
mburg
MBurg
mburg's Avatar
63
Drives: '22 230
OK
      10-08-2018, 09:59 AM   #12
mburg
MBurg
mburg's Avatar
63
Drives: '22 230
OK
Turns out that in the '19 model you don't need to remover the AC vent to get at the light switch. You can pry the light switch out alone.
      10-08-2018, 10:49 AM   #13
AndrewC1989
You don't even need to pry the switch out if you aren't replacing the entire thing. If you're just doing the button shaving method you can literally just pry the rear fog button out by itself.
2addicts
