Hi All,
Please help.
problem: I get an error when trying to flash ECUs. problem is: "FA must not be null when trying to execute a tal containing coding transactions". Screen shot attached.
I have read the FA and read the VIN so that is not the problem.
I have successfully coded HU_CIC with this setup just minutes later.
What I have done and am using:
- car is a 2012 BMW 328i sedan F30 with the N20B20 engine
- I have an ENET cable. I can connect to the car both in INPA+ and in E-sys (so cable seems fine)
- I have installed: (INPA+, ediabas, etc.) E-sys 3.27.1, E-Sys Launcher Premium 2.7.1_B135, v.63.1_PSdZData_Full
- I have a 50Amp charger on my battery - have no problem with voltage or keeping ignition alive.
- I have selected F030 in E-sys Launcher when installed .
- TargetSelector when connecting: Project=F020_17_11_521, VehicleInfo=F020 connection via VIN. Next pop-up I selected: F030 series and I-step shipment (which was read) F020-12-03-503 -> Connection Established [G168]
- I was able to code (successfully) the HU_CIC module
- I created SVT current, SVT future, TAL using Comfort mode
- in TAL-Processing, I have loaded the TAL, the future SVT, clicked on Read-FA, then on Read VIN.
- in the ECU matrix I have only blFlash, swDeploy, cdDeploy, and ibaDeploy columns checked (I have also tried just to update one module - same result).
- Check Software Ability comes back happy.
- a few seconds after clicking "Start" I get the error (as shown in the screen shot).
What am I doing wrong?
