M3 Suspension Upgrade?
12-14-2017, 11:37 AM | #1 |
121
Rep 239
Wondering if it is worth to upgrade the front suspension in my 07 328i RWD 6SPD
M3 Sway Bar Upgrade M3 front and rear Control Arm Upgrade https://www.fcpeuro.com/products/bmw...e93-bmwmcaktfr Is it worth it? Or should I just replace with OEM parts? Thanks in advance |
12-14-2017, 01:01 PM | #3 |
68
Rep 298
Drives: '16 330e
I did the front upper/lower control arms to replace mine (leaking hydraulic bushings) (DIY) I noticed a slight increase in harshness over bumps, but it's nothing major. This is on non-runflats.
The M3 (or TRW branded with bmw logo ground off) have solid inner bushings rather than hydraulic, which is generally the cause for increased harshness. Plus side is they wont leak. From FCP you'd be covered on parts warranty either way. You'll need an alignment afterward, the "wishbone" control arm will increase your track width and cause excessive toe-in. Drive safely to the shop if your tie rods are frozen like mine were. |
12-15-2017, 06:46 PM | #4 |
750
Rep 1,149
I just picked up M3 front and rear sways with bushings. Planning on install in a few weeks. Going on my 2011 328i E91 Wagon. Also doing a few track days. So I’m hoping it’s worth it.
12-15-2017, 11:13 PM | #5 |
2191
Rep 5,009
12-16-2017, 04:51 PM | #6 |
96
Rep 206
Do the front control arms (they are not going to give you a harsh ride; really hard to think of any detriment).
The rear control arms are not an upgrade; waste of your money (if you search on the 1 series forum you can find a write up on them). The sway is optional. The answer to that one is "it depends." You should upgrade springs and shocks before doing the sway. Search for reviews of the sway bar. |
12-16-2017, 06:47 PM | #7 | |
750
Rep 1,149
12-20-2017, 02:32 PM | #8 | |
300
Rep 379
I have done all the M3 bits and more on my 335is. In regards to arms and bars, you will notice a little improvement. Mostly though only under harder driving or track driving. The front arms do give a -0.25 of extra camber, which helps outside tire wear, a bit. You will more than likely not benefit much from upgrading the rear arms on a 328i unless you are going to the track. The bars will help the car stay flatter in turns of course. None of this will result in a rougher ride. You will have more feedback in the steering wheel from the road and tires. Optionally, you could go with coilovers, like Ohlins, which will completely transform the handling and ride of the car. I had Ohlins R&T on my 335is and sold them. All of the M3 arms, bars, sub-frame bushing, diff, etc. are still on. My 355is feels similar to driving my Ford Explorer. Coilovers are a huge step up! |
