12-05-2017, 03:28 PM | #1 |
Rep 62
Steering not centered after coding
I just did some coding with Bimmercode which was easy and fun. However, my steering wheel is now a little off center although the car tracks perfectly straight. Is there some parameter I could have thrown off? Steering angle sensor calibration?
I've tried disconnecting the battery and the turning the wheel through its full range but this did not help. Any thoughts? |
12-06-2017, 09:09 AM | #2 |
1837
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
Doubtful there's any way you can affect the steering calibration with something like Bimmercode or Carly for BMW, as there is still a mechanical connection between your steering wheel and the rack-and-pinion. The electric assist wouldn't interfere with that.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
12-08-2017, 01:55 AM | #5 |
25
Rep 120
Drives: 2018 BMW M240i
If you have access to ISTA+, you can reset the power steering to center the wheel. Your dealership can also perform this procedure for you, but if they do an I-level update for some reason to try and fix the issue, it'll undo your coding.
This normally happens anyway after coding/programming the EPS ECU in ISTA+. The BMW tools tell you to keep the wheel centered before doing any coding/programming, probably for this reason. |
