The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > E90 N43 engine - takes long to warm up
      12-01-2017, 01:20 AM   #1
samsami1983
Drives: e90 316i n43b16 2009
Hi to every one here... this is my first pots.
Car: E90 316i 2009 N43 engine
The Issue:
i had the car for about 2 months now, as the weather is getting very cold these days (-10 c)(Scandinavia) i am feeling that the car is taking long to warm up.
for example: after about 10 min of idling (ambient temp -9c) coolant is still at 30c and the ice on the windshield has not even started to melt.
the car eventually warms up and dose not over heat (coolant at 96 - 102 c)
suspecting that the thermostat is stuck open.
any way to test that without taking it off the engine as it is in a difficult place to reach.
i have access to IASTA and can use that.
Thanks in advance
      12-01-2017, 09:26 AM   #2
John320d
John320d's Avatar
31
Drives: BMW 320d E93
I take it that you have the cabin heating fans on during this warm up procedure. Turn them off. leave them off until you know that the engine temp is up. That minus 10 is the killer.
      12-01-2017, 12:18 PM   #3
samsami1983
thanks for the reply.
yes cabin heating is always on either on auto or on deice, I am comparing to my previous car (Mazda 3) after 10 min of idling it would be worm enough to start driving.
      12-01-2017, 12:33 PM   #4
John320d
John320d's Avatar
31
If the thermostat is stuck open the radiator will gradually warm up. If stat is working the rad will warm very quickly. Hold your hand on the top hose in engine bay.
      12-04-2017, 06:00 AM   #5
AndyVR
United Kingdom
12
Drives: E91 320i 2010 MSport
My N43 takes too long to warm up too, even running on the motorway it seems to stay at the 75 degree mark for ages, suspect Stat is stuck or not fully closing, sometimes even after a 20 min commute, it will not pass 90 degrees, only gets up to the proper 95 degrees if stationary for a while, i.e no airflow to the rad.
2010 E91 320i MSport
VW Corrado VR6
      12-04-2017, 06:57 AM   #6
rasa bmw
243
Drives: 640d sport/f31 330d x drive
if its getting to 90degrees the stat will not be stuck open...when mine were gone,the car wouldnt get to 83 degrees,
      12-04-2017, 09:55 AM   #7
John320d
John320d's Avatar
31
The Issue:
Thanks in advance
Check if your car has an auto rad blind and is it working.
      12-04-2017, 03:24 PM   #8
samsami1983
thanks John,
forgive my English but what do you mean by auto rad blind ...
      12-04-2017, 03:50 PM   #9
samsami1983
the specs for the stat on our cars is 97 and 102
mine will reach between 97 and 102 after about 20 min of driving with ambient around 0c, but in minus 10 c it takes longer and once it reach there some times it would drop quickly around 80 and it then starts to pick up gain.
once back in September (ambient +9c) with me revving up the engine and AC is off while standing, temp reached 108 before the ecu did something and the temp went back to 99.
these seems to me to be normal, what is bothering me is that it takes really long to worm from cold start at idle.
      12-04-2017, 04:01 PM   #10
John320d
John320d's Avatar
31
thanks John,
Air vents in front of the radiator open or close depending on the environmental temperature and road speed and shorten the engines warm up time. These were standard on the SE models but not the Sport model. I do not know if they are still fitting them on later models.
      12-04-2017, 05:21 PM   #11
samsami1983
now I understand you ... OEM 51747173571
mine dose has them and at idle they are closed.
      12-07-2017, 07:13 AM   #12
AndyVR
United Kingdom
12
Depends on ambient temp, speed etc. most of commute is 40/50 mph.
It's definitely not right, as I said maybe not fully closing, or sticky.
VW Corrado VR6
Tags
cold, coolant, e90, n43, thermostat
