FS: High end USA made alignment equipment gear Intercomp - NEW
11-29-2017, 11:21 PM | #1 |
40
Rep 134
INFO ON THE PLATES AND CC GAUGE HERE <---- CLICK: 1 x pair Digital turn plates (p/n 102191) 0.1° Increments 2,000lb Capacity Set of Two Measure Wheel Angle with the Industry’s First Digital Turn Plate Multiple Direction X & Y Movement High-Strength Bearings Large, Easy-to-Read Electronic Display 0.1° Graduation Range of ±30° (60° Total) Light-Weight Aluminum Construction Take Several Easy Measurements to be Used for Alignment. Including Caster/Camber & Ackerman Can be Placed on Top of Scale Pads Standard 9-Volt Battery Operation Dimensions: 13" x 15" x 1.625" (330 x 380 x 41mm) 1 x pair turn plate rear aluminum spacers (p/n: 100339-09) Features: Maintain Proper Weight Distribution by Keeping the Rear Level with the Front Plates Constructed from Light-Weight, Aerospace-Grade, Aluminum Dimensions: 13" x 15" x 1.625" (330 x 380 x 41mm) 1 x Digital camber caster gauge with magnetic adapter and carry case (p/n: 100005) Features: Indicates to 1/10° & has a ±20° Caster/Camber Reading Selectable 15° or 20° Caster/Camber Reading Up To 10 Times Greater Accuracy than Traditional Bubble Gauges Standard 9-Volt Battery Gives Up to 100 Hours of Operation Lightweight, Aluminum Design with Auto Shut-Off & Backlight Inclinometer Mode for Pinion & Strut Angles Built-in Diagnostic Mode for Resetting Camber Zero 1 x RIM CLAMP - AUTO (13 to 18"/330 to 457mm) (p/n: 100007) $2,100 USD. Local pickup in SF, Bay Area preferred. |
