BMW Style 179 Wheels? Replicas?
05-23-2008, 12:27 PM | #1 |
82
Rep 432
What do you guys think of these BMW (Style 179) wheels.
click here There very expensive! Does anyone make a replica that looks similar? Want to replace my 18" Style 189 with 19"
ED Trip - April 2015: SO F82 M4 Link to Trip Report
ED Trip - Jan. 2007: BS E92 335i Link to Trip Report |
05-24-2008, 03:36 PM | #2 |
82
Rep 432
Bump. Was hoping someone new some info on these wheels.
05-24-2008, 03:38 PM | #3 |
198
Rep 1,009
Wheels look good, you can get them cheaper at Tischer BMW http://www.trademotion.com/partlocat...catalogid=4462
06-18-2008, 02:33 PM | #5 | |
Critical Care Anesthesiologist
481
Rep 8,828
Drives: SMB F83
Get the wheels only and mount your favorite non-RFTs on them! I absolutely love my new ZCP/CSL combo with the Michelin PS2 non-RFTs
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist" |
06-20-2008, 05:54 PM | #7 |
100
Rep 2,528
Drives: 95 Avus M3 and 07 E90 Fam Car!
yeah there are some similar looking wheels. i wouldn't own OEM BMW wheels ever unless they came with my car and my car was the M model.
06-21-2008, 08:41 AM | #8 | |
481
Rep 8,828
Drives: SMB F83
Go get a CSL rear rim (Style 163) from OEM BMW made by BBS Germany and compare it to a CSL replica rear rim made in Taiwan. You might not be able to tell the difference on the outside, but once you put it on the balancing machine, you'd know the difference. I've seen both of them on a Road Force balancer and the results were so blatantly obvious.
06-21-2008, 03:26 PM | #9 | |
198
Rep 1,009
06-21-2008, 03:45 PM | #10 |
481
Rep 8,828
Drives: SMB F83
Just the amount of weights you need to put on the replica rim to balance it out is pretty crazy. The OEM rim required ZERO weights to balance it out w/o TPM; with TPM, only 60g of weights are required 180 degrees apart from the TPM. It was that perfect.
06-21-2008, 08:23 PM | #11 |
BimmerPost Supporting Vendor
2042
Rep 25,989
Making generalizations of the quality of non-oem "replica" wheels like that is borderline ignorant. In the aftermarket, manufacturers have the option of choosing how they want a wheel to be made. This includes the type of aluminum they use, how much aluminum, machinery, and quality of paint. Even quality control standard can be controlled. Minute changes can mean tens of thousands a month in overhead.
Surprisingly, a factory that makes "OEM" wheels can also make "cheap replicas." Reason being, the client (BMW, aftermarket brand, otherwise) have their own specifications of everything, from the type of material to use to how to do QC. Finally, regarding balancing of wheel & tire, most of the time the weights required are due to tire imbalances. It is much harder to make a balanced tire than a balanced wheel. If a wheel and tire require one ounce each, a pure stroke of luck can cause the wheel and tire imbalance to cancel each other out, requiring 0 ounces of weight. Or, it can mean 2 ounces of counterweight if the imbalances are put together. There are also secrets to making a wheel "perfectly balanced." For one, you can machine off small sections of aluminum within the barrel to balance out any minor imbalances. Or, if a certain wheel is designed to get TPMS, this extra step can be incorporated into the manufacturing process. At the end of the day, it just depends on how much effort a consumer makes to qualify their supplier, or perhaps, how much quality a vendor wants to cater. Sometimes its a matter of choice and availability. Or perhaps, its price point. But one thing is for sure, good/bad experiences especially in a forums environment makes its way to other perspective customers much faster than in other markets.
VMR|Wheels | 714.442.7916 |
