Replacing BMW e90 Professional Radio, Direct Swap?
11-26-2017, 10:28 PM | #1 |
Rep 12
Is it possible to replace the Professional Radio by swapping it out with a different one/ used one from a different car? Or does the radio have to be a specific one for sound systems like HiFi and Logic 7 etc? I am wondering this because the pixels on my radio are all out when the car is warm or in a hot climate. When it is cold outside, the radio is perfectly fine.
Thanks. |
11-26-2017, 10:37 PM | #2 |
1917
Rep 13,109
It has to be programmed for the type sound system
and options that you already have. If you are just changing it because the display is bad, which is a common problem, its probably easier to buy the display repair kit for around 100 bucks or send it in for replacement for around 150. If it came out of a car with the same options it would be plug and play. On a 2006 you should be able to code it with a simple D/K can cable and coding software. |
ryandunnahoo3.00 |
Tags |
hifi audio, pixels, plug and play, professional radio, radio |
