procedure for removing valvetronic servomotor sensor?
11-26-2017, 02:47 PM | #1 |
99
Rep 840
i have an n55 and i'm going to replace the gasket the sits between the valve cover and servomotor soon. i read that you have to turn it clockwise and then counterclockwise to remove? is there a procedure anywhere someone can point me to? i rather not mess this up and then having to replace the servomotor and taking the valve cover off. thanks in advance!
11-26-2017, 03:46 PM | #2 | |
1207
Rep 2,026
https://www.newtis.info/tisv2/a/en/f...-gear/CyzwchK9 I was just playing with mine today. I am not sure, but I think the only gasket is relatively easy to replace..: You just undo the two bolts and pull the gasket off. |
dleccord98.50 |
11-27-2017, 12:10 AM | #3 | |
99
Rep 840
11-27-2017, 07:21 AM | #4 |
1207
Rep 2,026
Those were just rags/rubber gloves I stuffed into places. I was drilling a hole through the valve cover and didn't want the shavings getting into anything (see the allen key?). I don't think you need that link if all you want to do is replace the gasket. You won't even need to take the valve cover off. That is, if you're talking about the one in the picture I showed. That gasket just bolts on over the valvetronic plug tube. You don't remove the motor itself for that.
11-27-2017, 11:48 AM | #5 | |
99
Rep 840
