Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > warning sign and tire pressure
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
      05-22-2008, 10:31 PM   #1
hipnotic
hipnotic's Avatar
Drives: e92 335i
2008 335i coupe  [7.00]
I got a warning signal today on my car. It was raining today in california and the weather was kind of colder than usual. The warning sign came on my dash when i started the car. It was a letter U with a exclamation mark in the inside of the U. I looked it in the manuel and it said either flat tire or low pressure tire. It doesn't look like i have a flat, but i checked the pressure of the tires and both my front and rear ran at 35. Is that okay? Could i reset it in my dash now or should i add or take out pressure on my tires? What do you guys think? Does this always occur when the whether gets too cold? I have sport package and the oem 18 inch wheels.
      05-22-2008, 10:51 PM   #2
Taittinger
Taittinger's Avatar
Drives: Monaco Blue E92
2007 335i Cpe  [0.00]
When did you check the pressure, cold? It is possible that a sudden drop in temperature lowers the pressure enough to register a warning.
'07 Monaco Blue 335i ordered 9/4 built 9/21 shipped 9/28 arrived 10/12 at dealership 10/18 vroom 10/19 christened 11/3...
      05-22-2008, 11:35 PM   #3
hipnotic
hipnotic's Avatar
Drives: e92 335i
i checked it 2 hours i parked the car.
      05-22-2008, 11:40 PM   #4
BMWE90
BMWE90's Avatar
Drives: E90 335
I would leave it for a long time before checking it. I usually give it about 4-5 hours and then take check the pressure.
      05-23-2008, 12:16 AM   #5
ssigur
Drives: e92 2007 Sport/Winter & Borla
Could be a fault TPMS or a Sensor. Try system reset per the OM. I think the systems goes on at 3 psi press differential. Good luck.
      05-23-2008, 03:17 AM   #6
e92kev
12
Drives: 2008 BMW JET BLACK 335i
same thing happened to me today. My car has like 1200 miles on odo and i got a low pressure sign. I just resetted the TMP and everything was fine again.
      05-23-2008, 09:36 AM   #7
hipnotic
hipnotic's Avatar
Drives: e92 335i
k, thanks. for all your input. it helped me. i am gonna try to reset it today and see what happens. hopefully the sign will go away. does this always happen though when the temp. gets a little colder than normal?
      05-23-2008, 09:46 AM   #8
Project3
-:- P3PRO -:-
Project3's Avatar
Drives: 2006 E90 325i (6 Speed Manual)
2006 E90 325i  [0.00]
yea bro. that has happened to me a few times. Just make sure that the TP in all the tires are the same, and then when the car is not moving, RESET the system and drive away. It will reset itself once you start moving again. Should be good to go then.
      05-23-2008, 09:47 AM   #9
hipnotic
hipnotic's Avatar
Drives: e92 335i
thanks bro
      06-14-2008, 12:30 AM   #10
E90330iS
Germany
143
Drives: BMW M4
2006 330i  [0.00]
same prob here, comes back once in a while
      06-15-2008, 09:05 AM   #11
Pappy
Resident Septuagenarian
Pappy's Avatar
Drives: '08 328i Coupe MT w/hand brake
Originally Posted by josh06lau View Post
..... i checked the pressure of the tires and both my front and rear ran at 35. Is that okay?
On my 328i coupe, it's 32 front and 35 rear. What does the sticker on the door say for yours???
Johnny
Sent from my keyboard using hunt and peck...
