11-22-2017, 08:08 PM | #1 |
224
Rep 450
Track Pads Need to Warm Up to Bite and Work Well
IMHO:
In other threads, some of the members that live with track pads have not highlighted two concerns. The first is the wear on the rotors which has been mentioned. The second, which could potentially be much more costly, is track compound initial bite and friction when cold. When you just start driving, track pads still being cold often don't have bite and friction coefficient to stop the car at the rate the driver expects, and there can lie the (thud) problem. Generally, most track pads need to warm up to work well. This varies by pad, but it shouldn't be disregarded. Also, if you only use track pads, other drivers of the car may be caught out.
'74 2002tii, Sienna Braun Metallic, Manual, Sold; '84 e28 533i, Burgundrot Metallic, Manual, Sold; '95 e36 M3, Avus Blau Metallic, Manual, Sold; '06 e60 M5, Silver Grau Metallic, SMG, Sold; '09 e82 135i MSport, LeMans Blue, Manual, Sold
11-23-2017, 01:12 PM | #2 | |
793
Rep 1,366
11-23-2017, 01:29 PM | #3 | ||
224
Rep 450
Bee Pee1736.00 |
11-26-2017, 07:31 PM | #5 |
1093
Rep 1,261
Drives: 20 BMW M2C 17 Mazda MX-5 RF
Eve all....
I posted this in another thread.. Another option is to run a rotor friendly track pad. I got sick of swapping out pads at the track especially when I had a couple students to worry about as well. I've had outstanding results running these 3 pads both on the street and at HPDE's. (Not an M2) Previous M3 & Evo X Raybestos ST43's Carbotech 10's, or 12's Porterfield R4's. All three are acceptable pads for street use even in freezing temps. All three will not eat rotors when cold (most track ready pads will destroy rotors until they heat up) All three have excellent initial bite, have 1200+ degree heat tolerance, zero fade. All three will dust a ton and squeal as you stop (runout) unless they're hot. Right now my go to pad is the Carbotech 12's. Their was a split within Carbotech and a additional brand G-Loc offers similar options. HTH, HAZMAT 2004 Mazda Rev It Up Finalist 2002-Present HPDE Instructor
2005-2006 BMWCCA Boston Chapter president
2004 Mazda Rev It Up Finalist 2002-Present HPDE Instructor My 2020M2C Build: https://f87.bimmerpost.com/forums/sh....php?t=1696726 |
rich8566608.50 |
