11-18-2017, 09:16 PM | #1 |
Rep 5
Pls help with fitment
Looking to purchase a set of used wheels from my local craigslist. Wheels are spec’d for an e92 and i have an f32. Pls help with fitment to see if i should purchase or not:
Specs are: 19 x 9.5 + 35 front 19 x 10 + 30 rear Thanks |
11-19-2017, 12:02 AM | #2 |
3117
Rep 4,364
front too wide, rear offset too low. its a no-go
11-19-2017, 06:49 PM | #5 | |
3117
Rep 4,364
front 19x8.5, +35ish, on 235/40/19. rear 19x9.5 or 19x10, +40 to +45ish, on 265/35/19. |
11-21-2017, 12:04 AM | #6 |
Rep 5
Leaning towards h&r super sport springs with bilstein shocks. But still debating on bc coils as well since both are priced pretty close. I dont plan on tracking or anything, dropping mainly for aesthetics.
11-21-2017, 12:05 AM | #7 | |
Rep 5
11-21-2017, 08:33 AM | #8 | |
851
Rep 2,771
Here is my car on stock suspension. 19x9.5 et37 all around with 255/35/19 tires. I used a 5mm spacer to clear the strut up front and they fit with a SLIGHT poke. This is why you will need camber up front. The rears at the specs you want can work if you do full -3 and a fender roll. Here's how she sits now. Camber is -2.4 all around on BCs. Front 19x9.5 et27 Rears 19x9.5 et25 I still have about 10mm up front to play with honestly. The rears are tight though. So at 19x10 et30... You will definitely need negative camber, a roll and mildly stretched tires. It just depends on how much you like the wheels and if you're willing to do the work to make them fit. Happy hunting. |
