Spark plug and ignition coil
11-17-2017, 11:05 AM | #1 |
36
Rep 157
Im planning on buying MHD stage 1 for my DD 2011 335i xdrive N55 with 53,xxx miles.
I want to change my plugs and coil before doing MHD 1. What spark plugs and ignition coil should I get? 2. What gapped on the plugs? 3. Where is the best place to buy? 4. What other things i need to check/replace before installing MhD Also,I’ll be doing Catless DP after installing MHD I appreciate any suggestions |
11-17-2017, 11:17 AM | #2 |
Clean is the new cool, keep it that way.
808
Rep 1,685
Stock Bosch ZR5TPP33S at stock gap and stock GN10571 Delphi coils.
11-17-2017, 12:42 PM | #3 |
17
Rep 57
Drives: 2013 E92 M3
11-17-2017, 08:06 PM | #6 |
1161
Rep 3,189
11-17-2017, 11:43 PM | #7 |
36
Rep 157
11-18-2017, 02:06 AM | #8 |
37
Rep 134
11-18-2017, 08:45 AM | #9 |
36
Rep 157
11-18-2017, 08:46 AM | #10 |
166
Rep 429
Drives: 2011 e92 335xi
What would be the optimal gap for Stage 1+ 93Oct?
2011 E92 335i xDrive
Pure Stage 1 | DV+ & Inlet | Injen Intake | M3 Cowl | ETS 5" FMIC & CP | Aquamist HFS4 Direct Port | CSF Radiator | Wagner Catted DP | BMW PE | Apex FL-5 | Michelin PS4S | 335is Engine mount | SDW Monoball thrust arms | UUC Swaybars & SS Brake lines | Bilstein B8 | Dinan Springs & Shock mounts | Whiteline RSFB | M3 Rear Control arms | Manzo Toe arms | Wavetrac LSD |
11-18-2017, 10:47 AM | #12 | |
36
Rep 157
Bosck plugs with delphi coils or Bosch plugs with eldor? I checked fcpeuro and it says ngk and eldor coil doesnt fit 2011 335i xdrive.. Only bosch and oem spark plugs Delphi and OeM coils |
11-18-2017, 04:17 PM | #13 |
1161
Rep 3,189
It doesn't matter. I went eldor because they were cheaper. Pretty sure NGK is also cheaper. I've been running them for over 40k miles with no issues. 30K maxed stock turbo, 10k PS2.
11-20-2017, 02:13 AM | #14 |
36
Rep 157
11-20-2017, 07:47 AM | #15 |
94
Rep 321
I am stage 2+ 93 octane on stock plugs / gap and coils. No issues.
Current: 2011 BMW 335xi | Wedge Tuned | Meth | VRSF DP | VRSF 5" Intercooler | VRSF Chargepipe | BMS Intake | xHP Stg 3
Totaled:2014 Audi A4 CTS K04 APR Tuned |
11-22-2017, 09:25 AM | #17 |
94
Rep 321
If they are old it is always good to replace for preventative maintenance
11-25-2017, 03:18 AM | #18 |
485
Rep 599
make sure you get the spark plugs from the dealer. they should have a BMW logo on them.
I bought the BOSCH ZR5TPP33S from a parts store and had misfire issues and felt like the car was kicking back. Went to dealer and bought the OEM plugs and problem solved. |
11-25-2017, 05:48 PM | #21 |
17
Rep 57
Drives: 2013 E92 M3
The ZR5TPP33S plugs are OEM plugs for the N55. You can use the Bosch ones as I've just changed my plugs two days ago and it runs super smooth.
11-26-2017, 12:20 PM | #22 | |
485
Rep 599
OE and OEM in terms of plugs is a big deal. The bosch ZR5TPP33S plugs do not have to pass the BMW quality control tests for that part, and do not have the BMW logo on them. Quality of these parts can vary greatly - they can range between the exact same part as the one that's put on the car on the production line (but minus the BMW logo...), to something that wasn't good enough to pass quality control, so the manufacturer just sells them as OEM. I rather pay the extra $60 for a better piece of mind. Last edited by MTK24; 11-26-2017 at 12:26 PM.. |
