11-15-2017, 06:31 AM | #1 |
Bus Media, Xenons, Spt Auto, Sun Pro Black Panel
41
Rep 115
Wheel alignment/tyre wear
My past 2 3 Series E90 and my F30 320 D both have suffered from excessive front inner and outer tyre wear (predominantly on the outside edge). This is despite the tracking being checked throughout the period of my ownership. I am now of the opinion this wear will happen even if you check the alignment weekly, and it is just a trait of driving on run flat tyres. My current tyres are OEM fit Pirelli Potenza’s.
The car runs perfectly straight, does not veer one way or another, and seems to handle as expected. Has anyone else had this problem, or does anyone agree with my thoughts? |
11-15-2017, 08:14 AM | #2 | |
6659
Rep 15,858
What pressures are you running? Lots of short trips? |
11-15-2017, 08:19 AM | #3 | |
75
Rep 399
11-15-2017, 08:25 AM | #4 |
41
Rep 115
11-15-2017, 08:27 AM | #5 |
41
Rep 115
I keep the pressures exactly as what the door card says, which I think is 2.3 bar from memory. But yes I do an awful lot of short trips in town, and seldom on the motorway.
11-15-2017, 08:43 AM | #6 | |
6659
Rep 15,858
I run above the placard pressure for my car. Learned the lessons on the E91. May require something like 0.2bar increase to balance out the wear pattern. |
ronime343.50 |
11-15-2017, 01:00 PM | #7 |
139
Rep 699
This used to happen with my 2012 F30 which was fitted with the P7's. The fronts wore the inner and outer edges and the rears wore out in the middle.
I had the wheel alignment checked and tried increasing the front pressures and reducing the rear but didn't like the handling with different pressures. A tyre fitter suggested it was my driving style in conjunction with the less flexible tyre wall and carcass of a run flat tyre. In the end I used to swop the wheels from the front to rear to even out the wear. Only an option if you have a square set up of course. |
11-15-2017, 01:07 PM | #8 | |
Grumpy Old Man
1334
Rep 1,306
I have done this ever since and increase the recommended all round pressures by 1 to 1.5psi. It definitely helps.
Alan
11-15-2017, 01:08 PM | #9 | |
344
Rep 834
BMW X1 sDrive20i ///M Sport MHT
11-15-2017, 02:15 PM | #10 |
10995
Rep 32,881
11-16-2017, 01:39 AM | #11 |
41
Rep 115
