11-14-2017, 05:10 PM | #1 |
Rep 15
Drives: 2017 Mazda MX5 RF Launch Editi
Spare tire pics
Pictures of the rear with the spare tire option.
11-14-2017, 06:24 PM | #2 |
BMW Client Advisor
3452
Rep 2,504
Drives: 2020 M340i
Thank you for the pics!
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com Top M Client Advisor in New England. |
11-15-2017, 02:11 PM | #5 |
86
Rep 510
Out of curiosity - what is the size of the spare tyre?
I know its a space-saver spare but I'm curious to see how different its overall diameter is to the full size overall diameter. Thanks, Tony |
11-15-2017, 02:30 PM | #6 | |
182
Rep 276
EDIT: Tire is 245/50 R19 which makes it actually 28.6" in diameter and 9.6" wide. Spare is 135/80 R18 which makes it actually 26.5" in diameter and 5.3" wide Last edited by bwcooper; 11-16-2017 at 07:58 AM.. Reason: Based on actual tire dimensions on sidewall..... |
11-15-2017, 02:46 PM | #7 | |
86
Rep 510
Tony |
11-15-2017, 03:54 PM | #9 |
Pygocentrus Piraya
927
Rep 1,008
Drives: 2021 BMW X3MC
No.
The amount of vertical space you lose was the reason I decided against this option.
kozzi
2021 BMW X3MC Donington Grey Metallic / Sakhir Orange & Black Extended Merino Leather / Aluminum Carbon Structure |
SpencerPJ65.50 |
11-15-2017, 03:58 PM | #10 |
182
Rep 276
You should be able to buy the tire and the jack, but the normal hole in the space under the cargo floor is presumably too narrow for it to fit there (be curious if someone without the spare could measure how deep that hole is) since they raised the floor about 3 inches to accommodate it. So you'd have to just leave it in the back like those who really wanted a spare in the previous generation did.
06-11-2018, 10:00 PM | #13 | |
Noob
53
Rep 109
See post #9 in this thread. For all practical purposes, you cannot retrofit the spare. It might be technically possible, but it won’t be easy or cheap since virtually all of the rear floor and side panels will change, and perhaps the supports too. The loss of 3” of vertical space is a lot to give up... I’ve been hesitating to order over this issue for several months... -Tom in SoCal |
06-11-2018, 10:14 PM | #14 |
Noob
53
Rep 109
While we are on the subject...
Can you fit two carry-on bags stacked on top of each other underneath the retractable cover? If so, I might not miss the space too badly. If not, it is a definite no-go. I haven’t found one with a spare on the lot, so can’t measure. -Tom in SoCal |
06-12-2018, 12:05 AM | #15 |
127
Rep 304
Drives: 2018 X3 i30xdrive
I wonder is anyone sells a "holder" you can mount on the side of the trunk, for a spare. So it's not floating around inside the back, and makes the back more planned usable.
Robert240.00 |
06-12-2018, 01:21 AM | #16 | |
Head Idiot
251
Rep 551
With the donut, no. Side-by-side, yes. With the donut, the height to the cover is around 15". See this: https://x3.xbimmers.com/forums/showp...&postcount=500 This might be useful, too: https://www.caranddriver.com/reviews...-driver-page-7 (the car shown has the donut) |
06-12-2018, 12:22 PM | #17 |
47
Rep 89
I don't have the spare/raised cargo floor, and to confirm beyond any doubt like some said no way a spare can fit. The width of the under floor cargo space is ~ 27" but it is only ~ 17" wide and about 6" deep.
06-13-2018, 01:54 AM | #18 |
1453
Rep 1,487
Drives: 2108 X3 xDrive30i
Good pics. Thanks for posting.
06-17-2018, 03:15 AM | #21 |
Rep 15
Could someone with the spare tire option please post pictures of the tools you received with the car (e.g. the jack stand, lug nut wrench, any other parts that come with it to change the tire)? Also, if there are part numbers on any of these parts that you got with your car, please list those as well. I didn't get the spare tire option, but ended buying a 19" spare rim/tire set (should be about the same diameter as my 21" rims/tires) just in case for longer trips and am trying to figure out what jack, wrench, jack crank, etc I need. Thank you!
06-17-2018, 05:57 AM | #22 |
254
Rep 452
you pay extra, you lose space, you're left with a load floor higher than the opening which means you will constantly have things falling out when you open the back hatch on any uphill park. there is no side rails for cargo management, and for all of this you get a mini spare. owned my last bmw five years never once had a tire issue. did however take my aftermarket aluminum "fence" from my previous car, volvo xc60 r design, which fit perfectly into the holes on top of the sliding rail locks which allows me to put groceries or home improvement supplies, or garden plants, etc back there and not worry about it going everywhere. I would not give that up for non run flats given the reliability of the modern tires.
ContactPatch2113.50 |
