F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Map update not starting in F31
proTUNING Freaks
      11-10-2017, 12:23 PM   #1
Largo
United Kingdom
Drives: 320d xdrive touring
I have downloaded BMW Europe move 2018-1 and moved it over to root of usb but when I plug it into the car nothing happens. I've read in different places about 3 files on CIC mimicking the 3 discs. But there is not that on the 2018-1 move. Can anyone help or has had the same issue??
      11-10-2017, 04:07 PM   #2
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
Drives: BMW 316d, BMW F40 116d
Can you make a image of the root of your USB?
      11-11-2017, 12:41 AM   #3
Largo
United Kingdom
There it is mate, 41 files straight on the usb no folder.
      11-11-2017, 03:14 AM   #4
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
That should do the trick.
But you do put it in the GLOVEBOX USB drive, right?
      11-11-2017, 03:19 AM   #5
Largo
United Kingdom
Yeah done both usb but nothing ?:
      11-11-2017, 04:20 PM   #6
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
That’s odd.. send me a pm so we can check it out on teamview.
      11-13-2017, 12:07 AM   #7
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Never installed move maps, but looks wrong on quick view. Is that how it appeared in initial download?
      11-13-2017, 12:08 AM   #8
Largo
United Kingdom
Yeah mate straight from unzipping it n straight onto usb. The person who sent it said there should be 41 files which there is??
      11-13-2017, 12:22 AM   #9
Almaretto
Almaretto's Avatar
2374
So there were not individual folders?
Is that exactly how it looked inside "NAVD_0000085F_255_004_240" folder?
      11-24-2017, 01:19 AM   #10
Largo
United Kingdom
Sorry just seen this no. There was just one folder that was the title BMW road map Europe 2018 move
      11-24-2017, 01:21 AM   #11
Largo
United Kingdom
Does anyone have Europe move 2017 to try out??
      11-24-2017, 08:50 AM   #12
massarico1
Drives: BMW 320d & PROUD 114d
Same problem in 2018 :S Any Solutions?
      11-28-2017, 02:31 PM   #13
Bubu88
Bubu88's Avatar
Germany
9
Drives: F80 M3
Same issues here with MOVE 2018-1
      12-02-2017, 05:05 AM   #14
massarico1
Found the problem
And solution.
Yesterday i finally update one friend F30 2013 with 2018-1 MOVE
In the firsts trys i use a usb pen 64Gb in NTFS format and don't working.
Solution
USB PEN 16Gb - Format FAT32 - put the files in the root of pen and VOILA magic starts
if your car have a usb in the glove compartment use that one, it is the only one that work for updates.
And you will need de FSC code
cheers
      12-02-2017, 08:57 AM   #15
Bubu88
Bubu88's Avatar
Germany
9
Drives: F80 M3
Hey massarico!
I used a 16gb stick anyway because my bigger one was used for Next-2018 Maps which are around 32gb.
But I think the FAT32 Format is the key point! I knew older BMW Systems can‘t deal with NTSF but I didn‘t think about checking my stick.
Sometimes the solution is right in front of you but you can‘t see it
      12-02-2017, 09:05 AM   #16
Largo
United Kingdom
Originally Posted by massarico1 View Post
Found the problem
And solution.
Solution
cheers
Found the problem
And solution.
Solution
cheers
Thanks for the advice but unfortunately I had formatted mine and was still the same :
Did your usb have 41 filed in the root?
      12-02-2017, 02:12 PM   #17
massarico1
Talking
Originally Posted by Bubu88 View Post
Hey massarico!
I just feel soo BLIND when I find the solution… x)..
Did you format in MAC or windows? What is the size of your usb pen? Your car have two or one usb ports? if have two ports, what port do you try?
Anyway the pic of the structure of the files in the usb pen in the root
Cheers
      12-02-2017, 03:10 PM   #18
Largo
United Kingdom
Hey massarico!
Cheers
Hey massarico!
Cheers
Formatted in windows, tried a 16gb and 32gb usb. Also tried it in both ports still no good :-(
      12-02-2017, 03:43 PM   #19
Almaretto
Almaretto's Avatar
2374
Must be formatted on Windows Computer.
MAC puts hidden files that makes it hard for BMW to read.
      12-02-2017, 04:11 PM   #20
massarico1
try once again format a 16 or 32Gb usb pen in windows FAT32, without name put the files in the "new" pen once again.
Follow the instrution on this PDF of BMW for the MOVE maps.
https://rsu.bmw.de/maps/pdf/content/...ET_EN_2015.pdf
      12-02-2017, 04:22 PM   #21
Largo
United Kingdom
Found the problem
And solution.
Solution
cheers
Out of interest what brand usb did you use?
      12-02-2017, 05:31 PM   #22
massarico1
Yes... i will send my pen for 150 dollars..
joking..
Toshiba 16Gb USB (old one) and the brand it will not make the difference.
Hope you can update your car
f30post
