F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Easy Seat Access F36
ARMA SPEED
      11-10-2017, 07:46 AM   #1
MrTomB
United Kingdom
32
Drives: 435D LCI EB
Anyone point me in the direction of any info on this? I have done loads of searches and found nothing
I want the seat to pop back a couple of inches on unlocking or door opening for the driver. I have Bimmercode ready for my first use at it, already got a list:
ambient lights not dependant on instrument lights, always 100%
Door handles light on reverse
Temperature with tyre pressure
Digital speedo in BC
Thanks
      11-10-2017, 02:00 PM   #2
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Drives: F32 435ix MSport
AFAIK, Easy Entry is not possible on Bimmercode using the canned options. You would need to go in to Expert Mode
If you DO give Expert Mode a try - check this thread for the needed coding changes + you will have to take some measurements as directed
http://f80.bimmerpost.com/forums/sho...3&postcount=30
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
      11-13-2017, 01:28 PM   #3
MrTomB
United Kingdom
32
Drives: 435D LCI EB
Stephan of Bimmercode is looking into it. But it's not easy due to all the variations and the fact we all have our seats in different 'normal' positions.
Maybe if a couple more reached out to him he might bump it up his list.
      11-13-2017, 02:54 PM   #4
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
As someone else mentioned in another thread about this-in the interim, you could always program one of the other seat memories to the back position.
Then just hit that mem button to move back before getting out, then the other for driving position when getting in
When coding there are a limited amount of hexadecimal values you can choose from based on your measurements and how far you want seat to move back from driver position. Bimmercode should be able to include those in drop down menu in a canned routine, user would just have to take measurements 1st
      11-13-2017, 02:56 PM   #5
MrTomB
United Kingdom
32
Drives: 435D LCI EB
That sounds like way too much effort for a BMW driver.
I will probably end up going the expert route in the Bimmercode app to be honest.
f30post
