11-09-2017, 05:19 AM | #1 |
391
Rep 960
M perf coilover factory pics b4 and after?
Hi. Am about to take delivery of my car soon and will be having MP coils put on. I️ was wondering if people have a before and after pic at the recommended height? I’ve read some of the threads but it’s not all that clear. The whole 600 mm fender to bottom of wheel throws me off. Never heard it described that way before
Also At recommended install. How much is the front and rears lowered 20mm 25 mm? Also What is most comfortable setting for daily Thanks in advance. |
11-11-2017, 08:04 PM | #2 |
197
Rep 155
I highly recommend lowering the rear to the lowest possible setting. There will still be "index finger wheel gap". As for the front, the lowest setting will give you maybe a 1/2 finger gap? I currently cruise around in the softest compression setting and factory recommended rebound settings. Good luck!
Living Life Turn After Turn!
[/url] F87 M2 Performance Edition - 2017-current F15 X5 35d - 2014-2017 E36 M3 - 2009-2016 |
11-12-2017, 02:56 PM | #3 |
227
Rep 245
Drives: M2 DCT MPerformance coilovers
At delivery and then with MP suspension, set lightly higher than recommended. I run bump and rebound at recommended settings though is probably a bit tight for everyday. Livable though.
11-12-2017, 02:59 PM | #4 |
475
Rep 549
Drives: The Bus
Garage List 2017 Ford Focus RS [0.00]
1971 Mk3 Austin Min ... [0.00] 2013 MINI R56 GP [0.00] 2013 MINI R55 Clubvan [0.00] |
Before & after (at factory recommended settings)
11-12-2017, 03:27 PM | #5 |
391
Rep 960
Thanks guys for the pic...
2 follow up questions, 1) vs recommnded settings how much lower is maxing out the lowering? Opplock1. If u have a fix on that that be great 2) ride settings,...So softest compression will help when going into bumps on local streets right? And rebound is for the speed out of the bump...? So softening up both ...would that be too bouncy? |
11-12-2017, 04:49 PM | #6 | |
227
Rep 245
11-13-2017, 05:01 AM | #7 | |
391
Rep 960
thanks I’m going to set everything softer when i get the car turkey week. Definitely softer...i only drive 4 miles per week. |
11-13-2017, 08:48 AM | #9 |
1776
Rep 4,512
11-13-2017, 04:30 PM | #10 |
793
Rep 1,367
Corner Balance and alignment...there is no ONE standard setting for coilover height...
You cannot check height by looking at pictures...you cannot eye ball this. It is science and geometry |
11-13-2017, 08:11 PM | #13 |
793
Rep 1,367
11-14-2017, 12:03 AM | #14 |
267
Rep 347
Adjusted to factory recommended height setting.
Rear is adjusted to the lowest setting. Front as seen on the picture still have approx. 8-10 mm left. Compression and rebound accordingly to factory recommendations. Cheers |
11-14-2017, 02:56 AM | #16 |
1776
Rep 4,512
M+M - Loving it. Mines AW and trying to save the pennies to get MPC/overs...
For those lucky owners with MPC/overs - do you have the alignment sheet post fitting - how much camber F & R ?
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
11-14-2017, 04:16 AM | #18 |
1776
Rep 4,512
If I read this right - your front camber differs by 20' L&R - I wouldn't be happy with that after spending a chunk on MPC's.....
11-14-2017, 02:08 PM | #20 |
227
Rep 245
didn't notice or question but now that you mention it? most of the driving here is not motorway and the roads have a crown in the middle sloping/curving away each side so I wonder if this is to compensate for that.
11-16-2017, 01:36 AM | #21 |
24
Rep 104
