N55 AT pulsating/throbbing at idle
11-08-2017, 08:07 PM | #1 |
78
Rep 239
So about three months ago i installed a vrsf dp on my N55 AT. Install was pretty doable thanks to a lift. Pretty sure I did everything correctly as its difficult to mix up the two o2 sensors. However when idling the car feels like it is jumping up and down 20-30 rpms even when warmed up.
Logs show just what I thought. When monitoring, the rpm bounces between a range of 20-30 rpms. New coils and plugs around the same time. Any thoughts? Mods are : BMS intake, BMS CP, VRSF DP, ARM FMIC, muffler delete, stage 1 MHD, stage 3 xHP.
2011 335i M-Sport E92
MHD E30 | Phoenix Racing CP | K&N Drop In Air Filter |Fuel-it Stage 2 LPFP | xHP Stage 3 | VRSF DP | ARM 5" FMIC + Hose Upgrades | GFB DV+ | VMR 19" v703 |
11-09-2017, 08:30 AM | #2 | |
104
Rep 263
11-09-2017, 09:18 AM | #3 |
1161
Rep 3,189
I've been dealing with this ever wince I installed my vrsf dp as well, 50k miles ago. I've got a new O2 sensor to put in to see if it fixes it. I think it just happens to some cars when going catless.
11-09-2017, 01:00 PM | #4 |
30
Rep 56
I have similar idle fluctuations. At this point it's been happening for so long that I'm not sure if it started right when the DP was installed, or a little while after that.
Coils and plugs were replaced around the same time. Exhaust shop confirmed there was no leak after installing. VRSF Downpipe, FMIC, ER CP, MHD Stage 2+ (93 Oct), Xhp Stage 3, K&N Drop-in. My car has been seeing lots of timing corrections lately, so I'm changing the plugs this weekend, I'll also be cleaning the MAF to see if that helps at all with this specific issue. I was very careful during the original install to make sure that the O2 sensors went back in the correct places (I mean, there's only 2..), so I highly doubt that's the issue. However I suppose it's possible that one of the sensors was damaged during the install, but if I have any luck solving the issue, I'll let ya'll know. For right now, it's really not that big of a deal since the car runs perfectly otherwise. |
11-09-2017, 01:01 PM | #5 |
396
Rep 1,210
I had/have two different issues with the 335i. The first one was with the JB4 the wastegate setting needed to be adjusted because it would pulsate under load. I would be climbing a hill and you could hear the pulse through the exhaust.
The one I still currently deal with is inconsistent idle when turning the car at low speeds or in reverse. I always just assumed it was due to the load of the power steering pump.
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD 2019 Audi TT RS | 10.5@130 SOLD 2020 F97 X3M | 11.0@123 2023 G80 M3 xDrive |
11-09-2017, 01:46 PM | #6 |
67
Rep 143
I have this issue too. Barely noticeable but its there... Still trying to figure it out but something i can definitely live with it as long is it doesn't hurt the car.
VRSF DP, VRSF 7" Intercooler, BMS OCC, Stg 2 LPFP, Custom MHD E30 Tune, Late Model E-Series N55
11-09-2017, 03:02 PM | #7 |
78
Rep 239
Yeah I am also having crazy pulses when in turning in reverse and drive on low throttle. Very weird. Happened before I modded anything
11-09-2017, 03:09 PM | #8 |
94
Rep 321
Same here. Seems like it is just a #335Problem
Current: 2011 BMW 335xi | Wedge Tuned | Meth | VRSF DP | VRSF 5" Intercooler | VRSF Chargepipe | BMS Intake | xHP Stg 3
Totaled:2014 Audi A4 CTS K04 APR Tuned |
11-09-2017, 06:53 PM | #9 |
139
Rep 227
I'm pretty sure BMW even had a bulletin about the idle fluctuating at low speeds or turning. Was a pretty common problem that they supposedly solved with DME programming... Maybe raised the idle slightly or something
11-09-2017, 08:00 PM | #10 |
40
Rep 177
Yeah I have the same issue. I noticed it after installing the dp which is catless. So the N55 must be very sensitive to no cat.
11-09-2017, 11:41 PM | #11 |
Rep 20
I've had idle issues for as long as I can remember, even when I was all stock. PPK flashed help some and got rid of the stalling for the most part. Now I'm FBO w/MHD and when coming to a stop RPMs drop to at or below 500 and continue to bounce around at idle. Sometimes fluctuations vary from 500 rpm to 900 rpm. It's stupid annoying but I've come to realize this is just a quick with this car. I think rpm adjustment via MHD would help this issue but I don't see them addressing this anytime soon.
11-14-2017, 08:17 AM | #12 | |
263
Rep 1,173
11-16-2017, 09:25 PM | #13 |
Sparkling Graphite Metallic FTW
151
Rep 3,212
What are the chances of it being due to the pcv valve in valve cover? My n55 also does idle surges. There was a time I did oil change and forgot to tighten oil cap my idle surge was insane I had to pull over and check. My pcv went bad so seals were howling once you pull oil cap noise goes away. So what are the chances of when I do valve cover idle surges go away? Let you guys know Sunday!!!
11-16-2017, 09:53 PM | #14 | |
30
Rep 56
11-16-2017, 11:28 PM | #15 |
40
Rep 177
I still have it even after getting a new VC, thinking it was my PCV valve. I honestly think it has to do with catless dps. Or something VANOS related. These cars are so complicated to the point were it's almost impossible to diagnose something.
11-27-2017, 09:51 PM | #16 |
30
Rep 159
My car does this every morning when I leave for work. I’m just always ready for it now. I get pretty pissed when I’m pulling into a parking spot and it jumps forward quick on me tho! Lol
11-28-2017, 10:49 AM | #17 |
45
Rep 194
Not saying this will solve your problem, but I had the same thing happen. I tried chasing it down for months and finally seemed to find where it's coming from.
Finally what seemed to fix my issue was when I switched back to my factory air intake instead of running the BMS intake. Haven't had this problem once since.
12' 335i
| CP-E CP | MHD | VRSF DP | ALPINA B3 | |
11-28-2017, 11:08 AM | #18 | |
12
Rep 73
12-02-2017, 10:12 AM | #19 |
40
Rep 177
12-02-2017, 11:29 AM | #20 |
1161
Rep 3,189
I had the issue with the stock intake and it didn't change when I put the BMS intake on. I've noticed when my oil level is closer to +1qt, it gets worse. If I keep my oil level at max it almost stops completely. So I believe it has to do with the vanos solenoids and oil pressure.
12-02-2017, 10:32 PM | #21 |
32
Rep 205
Drives: 2011 335i E90 AT M-Sport
I also have the rpm surging from 500 to 900 rpms when the car is in reverse or when making tight turns into parking spots. I have stock intake with K&N drop in filter. I am at a total loss with this issue and it is driving me crazy.
12-03-2017, 12:31 AM | #22 | |
40
Rep 177
