Do I need to worry about buying 'limited slip' gear oil?
11-06-2017, 01:58 AM | #1 |
15
Rep 73
I think the answer is "no", but I figured I'd ask before I bought the oil. The car is a 2009 328i xDrive E90. Did all of these have open diffs front and rear? After searching for a while, I found a thread that stated there were no limited slip differentials from the factory. (Non-M3, N52, auto trans, U.S.-spec car.) Just wanted to confirm that's the case.
BTW, has anyone used the Rowe brand gear oil? Decent stuff?? TIA. |
11-06-2017, 09:26 PM | #2 | |
Curmudgeon and Pedant
690
Rep 3,489
Most people use Redline for diffs. |
11-06-2017, 10:27 PM | #4 |
Touring cars rock
351
Rep 907
I switched from Redline to LiquiMoly and the Blackstone reports show reduced gear wear. I'd advise you do the same. I have been adding Ceratec to the diffs for over 12k miles and it has reduced noise from the diffs as well. I'll have a blackstone report on that combination in 16k miles when I change it next.
Sportwagon Daily: I've done some stuff.
kenmar21.00 |
11-06-2017, 10:36 PM | #5 |
15
Rep 73
Most people use 75W-90, correct? How important is the SAF-XO specification? I don't plan on keeping the oil in there forever, I'll probably change it around every 40,000 miles or so.
11-28-2017, 06:51 PM | #6 | |
21
Rep 132
11-28-2017, 06:55 PM | #7 |
21
Rep 132
Yes, 75W90. 75W140 is usually only recommended for LSD diffs. There was a good Bimmerforums.com thread about this years ago.
11-28-2017, 06:59 PM | #8 |
15
Rep 73
Guess I should update: I changed the front and rear diff oil. The rear is open. I used Ravenol VSG 75W-90. It meets the SAF-XO spec and has a neat straw in the container that makes it pretty easy to use. Seems like good stuff so far, but there are only a few hundred miles on the car since the change. WTH was BMW thinking when they neglected to include a drain plug on the rear diff? Oddly, they saw fit to include one on the front.
