OFHG - what else while I知 there??
11-02-2017, 01:11 PM | #1 |
99
Rep 840
Going to replace the gasket on my N55 pretty soon. Do I need new tensioner and belts? Also what about the coolant hoses and the connects to the housing? Thanks!
11-02-2017, 04:04 PM | #2 |
Is it the shoes!?
3884
Rep 5,112
Tensioner you should do if you see the pulley wobbling. I would do the belt since it may have oil on it from the leak.
I did the pulleys, tensioner, and belt because I like being thorough with things when I'm performing maintenance |
11-02-2017, 09:27 PM | #3 |
99
Rep 840
did you replace the bolts for the housing?
11-03-2017, 01:36 AM | #4 |
57
Rep 271
Drives: 2015 X5 50i, 2015 Macan Turbo
Agreed - OFHG leak is usually cause of belt contamination. Should inspect the tensioner while in there.
2013 E92 335xi 6MT MSport
JB4, PS2, Pure Inlet, N20 TMAP, ETS FMIC, Drop in filter, 4" AR DP, Fuel-it Stage 2, ER CP, GFB DV+, E50 |
11-03-2017, 07:44 AM | #6 |
94
Rep 321
I think he meant the opposite. I had to replace my belt, tensioner and upper pulley because of my OFHG leak. My lower pulley actually looked pretty good and didn't have any oil on it. My tensioner and upper pulley were pretty nasty.
Current: 2011 BMW 335xi | Wedge Tuned | Meth | VRSF DP | VRSF 5" Intercooler | VRSF Chargepipe | BMS Intake | xHP Stg 3
Totaled:2014 Audi A4 CTS K04 APR Tuned |
11-04-2017, 12:52 AM | #8 |
57
Rep 271
Yup - oil leak leads to bad tensioner / belt, not the other way around
Oil leak from housing gasket will contaminate and attack the rubber on your accessory belt, sling all over your drive pulley surfaces - which attracts dirt and gunks them up. Just inspect if you've had oil leak for a while... it will eventually need to be done.
JB4, PS2, Pure Inlet, N20 TMAP, ETS FMIC, Drop in filter, 4" AR DP, Fuel-it Stage 2, ER CP, GFB DV+, E50 Last edited by drmdvl; 11-04-2017 at 01:12 AM.. |
11-06-2017, 11:23 PM | #11 | |
99
Rep 840
Guys: if my car has the oil cooler, is there a gasket that needs to be replaced for that at the oil housing? |
11-07-2017, 08:52 AM | #12 |
94
Rep 321
I believe there are two ring gaskets. One to each hose. I don't have the oil cooler so they only replaced the one gasket for the housing for me.
11-07-2017, 09:35 AM | #13 | |
68
Rep 211
The vanos solenoids have an O ring and a seal on them that keeps oil in the engine. These can begin to leak over time. If your solenoids are working you can just change the seals. 1 set per solenoid: https://www.ecstuning.com/b-genuine-...t/11367548459/ The oil cooler has 2 O rings, one on each hose connection where it goes into the cooler housing. The cooler housing has a gasket where it is bolted to the filter housing. |
dleccord98.50 |
