MEVD17 emulation
10-31-2017, 05:01 PM | #1 |
227
Rep 182
MEVD17 emulation
The picture shows an ethanol fuel map being edited live on a bench ECU. There is a lot of free RAM on the MEVD17.2 as you can see, and some was already used. Less on MEVD17.2.G, but enough to be useful.
Do not judge the contents of the fuel map, it is just a random copy to test. |
11-02-2017, 11:50 AM | #2 | |
Member
159
Rep 269
Drives: 2012 E92 335i M-Sport
12’ E92 335i 6AT - Alpine White M-Sports Package
Mods - | MHD Stage2+ ACN91 OTS Map | K&N Drop-in | VRSF Kittenless D0wnpipe | VRSF CP | VRSF 7” FMIC | xHP Stage 3 | Euro Headlight Switch | Avant Garde M359 | Michelin PS4S |
11-02-2017, 01:11 PM | #3 |
227
Rep 182
To tune the main tables whilst the engine is running without having to turn off, flash each change, turn on, test, repeat. Can change hours of work into minutes.
11-02-2017, 04:05 PM | #4 | |
Member
159
Rep 269
Even cooler would be integration with a flex fuel sensor and the ability to swap tables on the fly depending on Ethanol levels.
11-02-2017, 05:02 PM | #5 |
396
Rep 1,210
I want this but with methanol injection. Some controllers have an external signal to tell the DME meth is flowing. At that point having the boost and timing targets change would be phenomenal.
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD 2019 Audi TT RS | 10.5@130 SOLD 2020 F97 X3M | 11.0@123 2023 G80 M3 xDrive |
11-02-2017, 06:19 PM | #6 |
227
Rep 182
There are ten pairs of new tables being blended with three different blending tables. The blending tables take input from another scaling table which takes input from any variable you like. This could be an ethanol content analyzer or another controller into a spare pin, a switch or a custom variable programmed through the CAN bus.
The ten pairs of tables cover fuel & timing (including spool modes), fuel correction/injector scaling, cold and after start enrichment, load/torque. The new tables are additional to the originals and you can switch between them. Over the next week I'll be unit testing them on the bench. If there are any queries or other ideas, please say! |
11-02-2017, 07:08 PM | #7 | |
1207
Rep 2,026
11-02-2017, 08:13 PM | #8 | |
Member
159
Rep 269
11-06-2017, 11:46 AM | #10 |
1207
Rep 2,026
11-06-2017, 01:39 PM | #11 |
227
Rep 182
Forgive me, not really spent much time tuning this platform, just coding for it. Can you explain what you want to do with idle speed? Do you want to adjust the idle speed relative to coolant, air intake or ambient air temperature blended by ethanol content? Do you have a specific table in mind that you have tried adjustments to or are you not self tuning?
I need to be very precise to change your request into reality. It could be a few lines of code if you know exactly what you want. |
bbnks21206.50 |
11-06-2017, 02:36 PM | #12 |
164
Rep 411
He has a single mass fly wheel. Raising the idle speed a little bit tends to help with the chatter that comes with the flywheel. Currently, there's no flash time option for idle speed with MHD as far as I know. I'm guessing that's why he mentioned it when you asked for other ideas
11-06-2017, 02:46 PM | #13 | |
1207
Rep 2,026
11-06-2017, 10:22 PM | #15 |
1207
Rep 2,026
11-07-2017, 05:01 AM | #16 |
227
Rep 182
There are quite a few idle speed tables that could be relevant. I suspect they will get tested once some other things are out the way, but it is more a calibration than emulation or flex fuel issue that I'm presently focused on.
