manual transmission harder to go in gears when cold
10-30-2017, 09:21 AM | #1 |
59
Rep 291
I am having a problem when it's cold outside below 35 °F, it gets harder for me to put get my car in gears. Even when try to rev match and stuff. But everything gets back to normal after the car has warm up fully to operational temperature.
My cars is a late N55 with 43k miles on it. I haven't done any modification to the car yet. When I had my N54, this never happened. A coworker of mine with a 6MT Honda SI have noted same problem as my car. Anyone else experienced this? Any possible guess as to what's happening and solutions? |
10-30-2017, 09:37 AM | #2 | |
1207
Rep 2,026
10-30-2017, 09:56 AM | #3 |
Is it the shoes!?
3884
Rep 5,112
This is expected behavior depending on the fluid used in the transmission. You can try swapping to a different fluid to change the cold shift characteristics. Recommendations are:
- Pentosin FFL-3 (OEM) - Redline D4 - Royal Purple Synchromax - OE fluid $$$$$$: 83222339221 |
10-30-2017, 09:59 AM | #4 | |
245
Rep 1,595
Drives: 2011 335i xDrive Msport
2011 335Xi 6AT - VRSF catless DP - VRSF 7" FMIC with turbo inlet pipe - VRSF chargepipe - Pure Stage 1 turbo - JB4 - E30 - xHP Stage 3 - Strongflex tension bushings - Whiteline RSFB - UUC rear swaybar
10-30-2017, 11:15 AM | #5 | |||
59
Rep 291
10-30-2017, 11:44 AM | #6 |
245
Rep 1,595
We probably know each other as I was in the DSM crowd in Minneapolis for many years. The niteryder I know is Josh S., but yours is spelled a little different and I know he doesn't have a BMW. I was at quite a few of the Cookout's Curt put on and took home some trophies. Small world!
10-30-2017, 12:18 PM | #7 | |
Is it the shoes!?
3884
Rep 5,112
I run Redline D4 in mine and I like it. It's also a lot cheaper. |
10-30-2017, 12:43 PM | #8 | |
59
Rep 291
I am starting to think maybe I will just have the dealer change it for when I go for oil change because I don't wanna deal with a cold garage now. |
11-04-2017, 07:48 AM | #9 |
57
Rep 271
Drives: 2015 X5 50i, 2015 Macan Turbo
Im using Redline MTL which I really like - getting into 20s 30s here in colorado and does fine.
2013 E92 335xi 6MT MSport
JB4, PS2, Pure Inlet, N20 TMAP, ETS FMIC, Drop in filter, 4" AR DP, Fuel-it Stage 2, ER CP, GFB DV+, E50 |
