10-29-2017, 09:44 PM | #1 |
Rep 11
map is showing REGIOs
Hi All,
After i done some coding, the map just showing REGIO, it is a bit annoying, but i wasnt sure which code is related to this, anyone have the same issue? |
10-29-2017, 10:46 PM | #2 |
BimmerPost Supporting Vendor
665
Rep 1,976
Drives: 2020 G20 320i M Sport
It's likely a bug in the firmware your CIC is running on. I've seen this happen before but it only occurs when you zoom out very far. You can try loading 2018-1 to see if it fixes the issue.
CMB Solutions Limited |codemybimmer.ca
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
10-30-2017, 09:38 AM | #3 | |
Rep 11
this happened even when i zoom in (50meter-500meter) |
