10-29-2017, 08:34 AM | #1 |
Rep 27
Display Key?
Hi all!
I was wondering if it was possible to retrofit the display key for my soon-to-be-arriving 2018 430i xDrive coupe. Has anyone done this? Thanks! |
10-29-2017, 08:03 PM | #2 |
878
Rep 1,687
Drives: 2014 428i and 2018 X5
What?
___________________ 2014 F32 428i M-Sport 2018 F15 M-Sport |
10-30-2017, 02:52 PM | #5 |
95
Rep 136
The display key is also available for both the 5 and 7 series. I have not heard of anyone coding that key even thou that would be pretty cool to do for the 4 series
10-30-2017, 07:57 PM | #6 |
Rep 27
Yes, the i8 key. I've tried doing some searches online and getting the key is easy, but coding is the issue. Im on the fence, but I figured I'd explore the option.
10-31-2017, 04:26 AM | #7 | |
No 55mph
1622
Rep 8,476
At the going rate of $1000 USD for the i8 display key (rare option even on i8) - I'd rather try the 5 or 7 series display key which can be had for much less
In addition to i8 key, I'm fairly certain you will also need the 434MHZ freq Receiver - normally included with key for the 1 grand + coding of the key to your VIN# (only i8 of course) Plus, there is the following disclaimer with any of the reputable vendors for the i8 key: Quote:
I do agree that being able to do this retrofit would be hella cool though Here is discussion on i8 Digital Display Key Retrofit - DIY from i8 Forum: http://bmwi.bimmerpost.com/forums/sh....php?t=1347091 This retrofit is akin to the 6WB Digital Dash Retrofit for our cars (which actually can be accomplished) - very nice option, but is it worth the going rate of $1600??? That's halfway to the cost of a healthy turbo upgrade which would give you much more JOY
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
04-12-2018, 12:17 PM | #10 |
11
Rep 59
BMW Display Key F30
04-13-2018, 12:11 PM | #12 |
17
Rep 98
In the video the windows go up with just a touch of the button. Is it possible to code this? for the windows to rise alone?
04-13-2018, 01:34 PM | #14 |
1890
Rep 3,877
The display key looks cool, no doubt about it, but in terms of functionality - you can do most of what is demonstrated on the video through your phone (assuming you have Connected Drive).
"Large increases in cost with questionable increases in performance can be tolerated only in cars and women."
04-13-2018, 03:14 PM | #15 | |
1039
Rep 1,509
If you have comfort access, you can code the windows to roll up when you hold the lock button on the remote. I think the factory setting is to roll up windows only when you press and hold the lock area on the door handle. |
04-13-2018, 03:51 PM | #16 |
8245
Rep 16,088
04-13-2018, 04:47 PM | #17 | |
17
Rep 98
But in the video he does not hold the button. It squeezes only once and the window rises alone.
or am I wrong? Quote:
04-13-2018, 05:01 PM | #18 |
8245
Rep 16,088
04-13-2018, 05:06 PM | #19 |
1039
Rep 1,509
