Winter wheel setup
10-28-2017, 12:56 PM | #1 |
32
Rep 357
Winter wheel setup
Hey what's up gents, I been considering running a winter wheel setup. Currently running 219m wheels but have my stock 18s 162s. Was thinking what square tire setup I could run with these. Maybe I could get a two more 8 162s so I could run four 8 162s with the tires. Would greatly appreciate your input. Thanks😊👌
11-01-2017, 06:02 PM | #2 | |
197
Rep 1,070
Another option could be 235/35 or 235/40 ??????
JWebb335xi
MHD / Wedge / 93 Octane/ xHP / FMIC / Inlets / Catted DPs / CP / DVs |
11-05-2017, 08:22 PM | #3 |
32
Rep 357
Would that size be ok in the xi? Also wouldn't that stretch alot with the rear 8.5 rim?
11-06-2017, 06:11 PM | #4 | |
Touring cars rock
351
Rep 907
We do Mt. Baker all winter, almost weekly (and drove NYC-VT for years to ski), and I'll do 50-70 up the mountain roads when there's many feet of snow on the ground with 225's and good Conti snows. There's absolutely no reason to have any more tread width in winter if you see lots of rain & snow. Just get proper tires. As for staggered, these cars understeer from the factory as it is. staggered setups only aggravate an already bad characteristic. Square setups are much better balanced, especially if you are in a 325/328/330. Staggered in a winter setup is just plain stupid. I run 245's square in the summer.
Sportwagon Daily: I've done some stuff.
11-06-2017, 08:00 PM | #5 | |
32
Rep 357
11-06-2017, 10:23 PM | #6 | |
Touring cars rock
351
Rep 907
If you don't need 18" rims for brake clearance, running them is profoundly counterproductive. Not only is the wheel/tyre combination heavier, you have far more risk of damaging a wheel if you hit a pothole, etc. This liklihood is far higher in limited visibility in winter with reduced hours of sunlight. Honestly I don't even run 18's in summer, as my summer tyres have more than adequate sidewall stiffness. 17x8.5 in summer & 17x8 winter is almost ideal on our heavy cars with no real power. Everything else is just posing.
11-07-2017, 01:44 PM | #8 | |
Touring cars rock
351
Rep 907
Either way, square 225's on 8's for winter at the widest. I ran 205's in deep snow back east and that was better than 225's by a country mile. You may not be driving to killington every weekend, so 225's may be the way forward. No wider.
11-11-2017, 09:53 AM | #9 |
207
Rep 602
This winter I switched from 225/40/18's all around to 235/45/18's and couldn't be happier, the extra sidewall and ground clearance really helps in the winter.
11-11-2017, 01:19 PM | #10 |
32
Rep 357
11-11-2017, 02:00 PM | #11 |
Touring cars rock
351
Rep 907
I spent 17 years driving in his exact neighborhood, and I've tried wider and narrower in winter, and I disagree 100% with going wider in winter. So will every one of the tyre manufacturers.
Take a look at what TireRack.com has to say on this subject here. You're just flat wrong about going wider. The laws of physics don't re-write themselves in winter. Have you ever watched or seen a WRC race in the snow (World Rally Championship)? Most of those professional race drivers run between 165 and 185s on high horsepower WRC cars in snow conditions. More weight to the ground per sq in of contact patch is key in snow. Note the width of these tires:
11-11-2017, 03:34 PM | #13 |
Touring cars rock
351
Rep 907
Those are nice wheels, I'd save them for when there's no salt on the road. Get a used set of 17x8's for $250 and mount up some 215's or 225's.
11-13-2017, 06:14 PM | #15 | |
197
Rep 1,070
I live in the Chicago area where we typically see several 2-4" snow falls, lots of slush and cold/wet conditions but not typically massively deep snow. FWIW, I'm very comfortable with my car's ability to turn and stop in winter conditions with this set-up, but the dry handling is NOTHING like with summer PSS or PS4S..
JWebb335xi
11-15-2017, 04:50 PM | #17 | |
Touring cars rock
351
Rep 907
For those that don't know, Mt. Baker receives more snowfall than any other place in the continental US. To give you an idea, we set the world record for snowfall in a single year in 98/99 when The Mount Baker Ski Area reported 1,140 inches (95 feet) / 2,896 cm (29 meters) of snowfall in one season. I drive in snow a LOT.
11-16-2017, 05:09 PM | #18 |
285
Rep 615
Drives: '11 E92 335xi 6MT
I live in Madison, WI where we get what I would call persistent moderate amounts of snow. It's not too often that we get more than 6 inches and I'm not a skiier or any other kind of winter adventurer. So...I have my stock 193Ms with Michelin Pilot Alpin PA4s in the stock staggered sizes, 225/40-18 front and 255/35-18 rear.
It was probably a dumb choice since narrower is better for snow tires, and the rear winter tires were $300 each, but I figure my lowered suspension is already compromising my winter traction so what the hell. Was this smart? Probably not. |
