10-27-2017, 08:47 AM | #1 |
MPerformance
25
Rep 108
Coolant alert twice in 2 weeks?? M240i
Hey buddies, any of you have to fill your coolant regularly?
Current: ///M240i Convertible
Previous: 330D | 320D | 318i |
10-27-2017, 08:52 AM | #2 |
2924
Rep 1,303
Drives: 2021 C8 Corvette 1LT
I have not had to regularly fill my coolant, no. However, BMW did have to refill my coolant when I blew a coolant line at full throttle down the autobahn after they swapped my turbo and didn't secure a coolant line properly.
Have you noticed any leaks? Check the front radiator fan and make sure it's not rubbing on anything (that's where my coolant line was rubbing and eventually ruptured). |
10-28-2017, 04:02 PM | #4 |
221
Rep 314
Twice in week may be cause for a checkup. I had to fill mine over the summer after warning popped up. Was about a pint low. No issues since.
10-29-2017, 09:02 PM | #5 |
38
Rep 57
My warning just came on around 5k miles, I just had it topped off at the dealer on Friday. I do think this is a "thing" with the B58. I would definitely have your car get a thorough inspection though, no need to guess whats wrong on a 50k car.
10-29-2017, 09:05 PM | #6 |
689
Rep 908
Drives: '17 F22,15 E84 M Sport,02 R53
Mine did it on Friday - car has 13,568miles. I believe it's since the air temps have fallen (winter approaching in N.America) so if any evaporation took place - the colder weather has the coolant contracting more overnight. I took it to the dealer and they topped it off - both engine coolant and intercooler coolant. I will keep an eye to see if this is a chronic problem ot a minor occurrence.
10-29-2017, 09:37 PM | #8 |
MPerformance
25
Rep 108
Thanks for all the replied. I've booked Emma in for a service on Friday and will let you know if something is amiss.
10-30-2017, 10:36 AM | #10 |
5491
Rep 5,339
Which tank is going low? Aren't there two? One for the engine block and one for the liquid intercooler which is built into the intake manifold. If it's the intercooler one, I'd be worried there's a crack in the intake manifold and it's being ingested by the motor.
Saffa_G24.50 |
10-30-2017, 02:08 PM | #11 |
689
Rep 908
I've had new cars drop their level in their first winter and never again use coolant. My 2002 R53 did it, my 98 Golf did it and my wife's 2015 X1 did it - none of those cars consumed coolant subsequently.
That being said doesn't mean that the B58 is defective but it also doesn't say it won't repeat - will just have to observe and see. Last edited by WolfGTI; 11-01-2017 at 04:46 PM.. |
Saffa_G24.50 |
11-01-2017, 03:44 PM | #12 |
60
Rep 140
I also had the low coolant light come on twice in the last week The first time the dealer topped off the smaller coolant tank and said the other one was fine. Today it was the bigger tank, there was nothing showing. They sent out some coolant and the light went off. Getting it checked out now. I will report back.
Pat |
Saffa_G24.50 |
11-02-2017, 10:03 AM | #13 | |
MPerformance
25
Rep 108
11-05-2017, 07:14 PM | #14 |
MPerformance
25
Rep 108
So I got Emma back!
Service advisor said she had an abnormally lower level of coolant, in the larger tank. They pressure tested both and all passed. No cause for concern, however he did say that if she gives and alarm again for low coolant I should come back and they will do some more diags. Nevertheless she also got a gut full of new oil, a nice wash and I got to drink copious amounts of coffee while I waited for her. If it happens again I'll let ya'll know
11-05-2017, 09:14 PM | #15 | |
583
Rep 1,117
Drives: 2015 BMW M235i
Dylan861330.00 |
11-07-2017, 09:58 AM | #16 |
60
Rep 140
I had mine checked out, no leaks. It got very cold here recently so we are assuming seasonal losses.
The coolant tanks are quite small. It does not take much for it to show low. I just wish there was a temp gauge, that way if it happens again I can keep an eye on the temp. Pat |
11-07-2017, 10:06 AM | #17 | |
MPerformance
25
Rep 108
11-11-2017, 05:23 PM | #18 | |
47
Rep 370
11-12-2017, 11:07 AM | #19 |
251
Rep 558
Please share the steps for how to display these values in the cluster. Thanks.
My 2017 M240i: MHD, xHP, Modded OE Intake, AA GESi 400 CPSI Cat DP, Dinan Mid-pipe, M Performance LSD & Rear Diffuser, BMS Exhaust Tips, Apex EC-7 Wheels, M-Tech Front Lip, iND Painted Mirror Caps, Smoked Reflectors
11-12-2017, 11:48 AM | #20 | |
67
Rep 181
If its burning coolant then its a big problem if its just leaking its probably minor leak. Either way, under warranty so just let em look at it. |
11-17-2017, 05:34 PM | #21 | |
47
Rep 370
My M240i has a slight variation to the dash that's shown, but essentially the same process. You'll need the sum of the last 5 digits of your VIN to unlock. Takes less than a minute to get too with the ignition on or the engine on. Unfortunately, you have to do it every time you start the car if you want this information. To me, not a big deal as I only want the oil temp on the track. I can't get the B58 oil temp above 110C. |
11-18-2017, 06:58 PM | #22 | |
251
Rep 558
