Power Steering Reservoir Replacement
10-26-2017, 01:44 PM | #1 |
162
Rep 231
My PS is sounding a bit noisy even after I've turkey bastered out the fluid a few times. I thought I'd replace the PS Fluid Reservoir next. It's only about a $25 part. I looked at the Pelican Parts instructions and it seems pretty easy except for the hose clamps. These are apparently crimp ones and I don't have the proper tool to crimp in replacements. Is it OK if I replace the clamps with standard screw type clamps?
10-26-2017, 01:52 PM | #2 |
10
Rep 101
I replaced my reservoir due to noisy power steering a few months ago. It didn't make any difference - almost certainly the pump is dying. Going to replace the pump this weekend.
I used standard screw clamps. No issues with leaking.
E90 330i SE Manual / Bilstein B12 Pro / M3 Control Arms / Performance Exhaust / CDV Delete
10-26-2017, 03:07 PM | #4 |
10
Rep 101
Good luck. It's a pretty easy job to replace the reservoir.
02-20-2018, 01:31 PM | #6 | |
25
Rep 159
02-20-2018, 01:35 PM | #7 |
Life is better with burnouts
98
Rep 611
Drives: BMW
02-20-2018, 01:39 PM | #8 |
25
Rep 159
He is right. You can also use a shoe string. Or silly string.
02-20-2018, 01:39 PM | #9 | |
453
Rep 2,973
The hoses aren't high pressure hoses. The pump to rack is a high pressure connection.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
CTinline-six6879.00 |
02-20-2018, 01:41 PM | #10 | ||
25
Rep 159
02-20-2018, 02:17 PM | #11 |
1007
Rep 2,243
Drives: 2007 328i / 2014 M235i
Try to get good quality clamps with rolled edges
Screw clamps are fine |
Efthreeoh17366.50 F22_Raptor118.00 |
02-20-2018, 03:42 PM | #12 | |
1905
Rep 6,968
Drives: 2007 Black/Black 335i e90
02-22-2018, 12:57 PM | #13 |
157
Rep 848
Drives: '01 E39 540iA, '09 E90 M3
E90 M3 DCT LCI | E90 LCI N54 M-Sport(retired) | E90 Technical Docs download: http://j.mp/bmwe90docs *good read, very detailed.
02-22-2018, 11:34 PM | #14 |
25
Rep 159
02-23-2018, 12:08 AM | #15 |
Art Collector
2427
Rep 3,450
Perhaps I’m missing something here, but I did this exact job today and simply used standard pliers to undo these crimp-style clamps, and then redo them back up once I had the new reservoir into place...
No leaking; works fine. *edit* Used flathead screwdriver to disengage clamps, and then used pliers to re-engage them. |
TheMidnightNarwhal2669.50 |
02-23-2018, 05:18 AM | #16 | |
17367
Rep 18,769
Dude why did you join this Forum? You make a complete ass of yourself in every thread you post in. Either you are just plain maniacal about posting bullshit, or a complete automotive repair dumbass. Which is it?
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
MysticRob572.50 |
02-23-2018, 03:13 PM | #17 | ||
25
Rep 159
If all above is true, mind your own business. You are a poor salesman. |
02-23-2018, 05:00 PM | #20 |
453
Rep 2,973
The time it takes for assembly?
The steering pump pressurizes the rack. Fluid is pulled from the reservoir under negative pressure. The return is residual positive pressure after exiting the rack.
02-23-2018, 05:05 PM | #21 | |
25
Rep 159
So you all know more than bmw who spends millions on research and engineers with multiple degrees. Yeah let's replace that hose which is just crimped for show with a hose from Home Depot. No no, let's get really in genius mode and use the hose from harbor freight. Bmw didn't know what they were doing when they chose that specific type of hose. Go ahead and Mickey Mouse and shortcut. It always is the best option. |
02-23-2018, 05:24 PM | #22 | |
3973
Rep 7,215
JFC, you litterally post the dumbest shit on this forum. |
