Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Late​ ​E-Series​ ​N55​ ​MEVD1726​ ​DME​ ​Removal​/Benchflash Guide
      10-23-2017, 05:36 PM   #1
Toome
Member
Toome's Avatar
Drives: 2012 E92 335i M-Sport
With MHD officially out of beta for (2012+) late E-Series cars, more people want to unlock their ECU's. I have attached a guide I made on how to remove the DME in order to ship it off to be unlocked for those in remote locations or for those who'd rather turn their own wrench.
ECU Removal:
https://docs.google.com/document/d/1...it?usp=sharing
Benchflash:
Please feel free to point out any errors or suggest changes.
12’ E92 335i 6AT - Alpine White M-Sports Package
Mods - | MHD Stage2+ ACN91 OTS Map | K&N Drop-in | VRSF Kittenless D0wnpipe | VRSF CP | VRSF 7” FMIC | xHP Stage 3 | Euro Headlight Switch | Avant Garde M359 | Michelin PS4S
Appreciate 7
      10-24-2017, 03:29 AM   #2
BMWcurious
United Kingdom
227
Drives: Various BMWs
Good guide. I tape over the intake ports whilst the intake manifold is off.
      10-24-2017, 05:44 PM   #3
Wksk
79
Drives: 2013 335i e92 6spd goes vroom!
Wow, you actually made the guide. Very nice. I 2nd bmwcurious' post. I used those blue shop towels to plug mine.
      10-24-2017, 06:57 PM   #4
Toome
Member
Toome's Avatar
Took a while but finally got around to it.
I listed that as a step but forgot to take a picture of it.
      10-26-2017, 08:52 PM   #5
robrxt
Drives: 12' E93
I will update this thread with another guide on how to do the actual bench flash later.
Looking forward to the post of how to bench flash and unlock the DME. I want to do this. Thanks!
      10-27-2017, 03:41 AM   #6
BMWcurious
United Kingdom
227
Main points on opening are to use a blade with an exposed length that will only just cut through the sealant and not hit components. I also put mine in the oven at 100C for 15 minutes first. Avoid static by grounding yourself and the ECU at least briefly before connecting the boot pin if like me you use an actual pin and grips on the table so you are effectively touching the boot pin. http://f80.bimmerpost.com/forums/sho....php?t=1264155
      10-27-2017, 09:00 AM   #7
nissubaru
233
Drives: 09 335i MSport + 1990 300ZX TT
N54 guy over here seeing this thread for the first time...what? Is your DME no longer in the cowl on the passengers side? But instead it's under the intake manifold?
Interesting seeing such a change. Just out of curiosity, what is over there under the passenger side cowl on the N55 if not the DME box?
      10-27-2017, 09:51 AM   #8
weehe126
1161
Drives: 2017 340i
Yes, all N55 DMEs are under the intake manifold. There is a heat sink in the manifold to help keep the DME cool. The box under the cowl is still there, just has a few wires and fueses.
      11-02-2017, 11:25 PM   #9
Xdrive35i2014
56
Drives: X1 35I
Thanks for the guide! Any updates on the actual bench flashing guide?
Mod List: Twisted Tuning MHD tune, XHP3, ER Charge Pipe, catless DP, ER Competition FMIC, Pure Stage 2 Turbo, PURE High Flow Inlet Pipe, ER Outlet Pipe, GFB DV (Plus), Gruppe M intake, Supersprint full exhaust
      11-02-2017, 11:31 PM   #10
Toome
Member
Toome's Avatar
Should be done next weekend. Sorry for the delay, I've been out of town.
      11-09-2017, 11:48 PM   #11
Xdrive35i2014
56
Drives: X1 35I
Hey Toome, any updates?
      12-09-2017, 03:04 PM   #12
Toome
Member
Toome's Avatar
Sorry for the delay, but I finally updated the OP with the Benchflash Guide. Still a work in progress so don't be afraid to suggest changes. Feel free to PM me if you have any questions.
      03-02-2019, 08:07 PM   #13
Schmidty335i
Drives: E92 335i PS2 turbo FBO JB4
ECU Removal:
Benchflash:
YOU SIR ARE AWESOME!! i followed your instructions and was able to unlock my DME! got the ktag for 60 bucks then i paid 199 for mhd loaded the JB4 BEF and it is running like a champ! thanks again for making this DIY! i would have sent it off otherwise and had to wait.
BTW if anyone is by Ridgecrest California and needs help just message me.
Toome159.00
      03-29-2019, 04:28 PM   #14
Turbod
Turbod's Avatar
Drives: 2014 E84 X1 35i M Sport
Has anyone that has done this run into issues after bench flashing the DME? I have 4 codes that I cannot clear and the half engine light. Looking up code descriptions isn't always easy but from what I found most seems to relate to throttle valve.
28B0
28AB
28A4
28A9
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD
2019 Audi TT RS | 10.5@130 SOLD
2020 F97 X3M | 11.0@123
2023 G80 M3 xDrive
      04-08-2019, 11:08 PM   #15
ferocity02
Drives: 2013 135is
28B0
28AB
28A4
28A9
Did you remember to plug the throttle body back in?
      04-08-2019, 11:11 PM   #16
ferocity02
Drives: 2013 135is
Remember to clear codes on the DME before trying to start it for the first time. I didn't and the car ran like dog shit, couldn't idle, loud as hell (wastegate wide open). The code was 36FD "DME main relay, plausibility: prematurely dropped out". After clearing it ran perfectly fine.
      04-08-2019, 11:39 PM   #17
Turbod
Turbod's Avatar
I was positive I deleted my post. Yes the throttle body wasn't plugged in.
2023 G80 M3 xDrive
      04-05-2020, 01:26 PM   #18
Snowboardkid503
10
Drives: 15 X5 F15 35i
would this happen to work for F15 X5 35i, the unlock exe?
      04-12-2020, 06:43 AM   #19
Toome
Member
Toome's Avatar
Go on RealOEM and make sure the ecu part number matches an e92 335 from 2011-2012.
      04-13-2020, 07:24 PM   #20
Snowboardkid503
10
I ended up trying and worked
Toome159.00
      04-13-2020, 07:48 PM   #21
robrxt
Drives: 12' E93
I was under the impression that bench flashing DME was no longer needed to flash MHD.
      04-14-2020, 02:21 PM   #22
Toome
Member
Toome's Avatar
Not for the 2012-2013 E series N55's. Unlock is still required.
