10-22-2017, 10:02 AM | #1 |
19
Rep 52
G30 - ASS Coding
Hi All,
I am new to coding and wondering how can I code g30 auto start/stop option to remember last setting (off) that was set prior to locking the car, or to set auto start/stop option default value to be always off in comfort mode. Since this will be the first time to code g30, can you please let me know which esys software version is recommend to use as well as other files, and where to find ASS setting? Thank you. |
11-27-2017, 08:32 PM | #4 |
19
Rep 52
I was able to code stop/start to remember last setting. I was able to find an option TCM_MSA_MEMORY under:CAFD_00002742_000_105_003.ncd. Paramethers Wert should be set to Wert_01 and Werte=01.
11-29-2017, 08:49 AM | #5 |
3091
Rep 3,063
Drives: 2023 iX M60 Oxide
Which version of ESYS did you end up needing for g30?
12-02-2017, 02:18 PM | #6 |
19
Rep 52
Sorry, it took me a while to make a video.
BMW G30 ASS Coding to Remember Last Setting BMW G30 ASS Coding to Remember Last Setting - E-Sys 3.27.1, PSdZData_v3.62.5_Lite - During the coding enginee is OFF, ignition switch is ON, key fob is in the car. You can find all info in here: Last edited by vkoprivica; 12-05-2017 at 10:02 PM.. |
pemz26.00 fichtenweg7.50 |
12-03-2017, 11:19 AM | #9 |
2373
Rep 8,364
12-05-2017, 01:29 AM | #10 |
26
Rep 79
So I did the same this morning. But during coding the car turned itself off and got a service message in the screen to visit the nearest dealer. At the same time got all green from Esys. After restarting the car, message was gone and all seems well.
fichtenweg7.50 |
12-05-2017, 02:25 AM | #11 |
2373
Rep 8,364
You cannot program or code DME/DDE (engine ECU) while active/running. So, You must either have either not have external power source or left accessory mode running too long before attempting coding.
fichtenweg7.50 |
12-05-2017, 02:28 AM | #12 |
26
Rep 79
Ok, so leave the engine off and contact on. Gonna try again in a few.
EDIT: It worked. Thanks again Almaretto, you're a big big help! vkoprivica too! Next step is, enable start in ECO PRO mode... :-) Last edited by pemz; 12-05-2017 at 02:46 AM.. |
12-05-2017, 09:37 AM | #13 |
2373
Rep 8,364
12-07-2017, 10:40 AM | #14 | |
11
Rep 102
ASS coding
TCM_MSA_MEMORY under:CAFD_00002742_000_105_003.ncd. Paramethers Wert should be set to Wert_00 and Werte=01. Above, in this thread, it says: I was able to code stop/start to remember last setting. I was able to find an option TCM_MSA_MEMORY under:CAFD_00002742_000_105_003.ncd. Paramethers Wert should be set to Wert_01 and Werte=01. I forgot what default was. Can you tell me which is correct or does it not matter? Thanks! |
12-07-2017, 10:53 AM | #15 |
11
Rep 102
ASS coding
Also, to confirm:
"Engine is OFF, ignition switch is ON, key fob is in the car." I just have to code this in the 15 minutes the car stays active in the above state. Correct? Thanks again. |
12-07-2017, 11:49 AM | #16 |
2373
Rep 8,364
12-07-2017, 12:33 PM | #17 | |
11
Rep 102
And am I correct about "Engine is OFF, ignition switch is ON, key fob is in the car."? Thanks |
12-07-2017, 02:17 PM | #18 |
2373
Rep 8,364
12-10-2017, 09:30 AM | #19 |
11
Rep 102
G series coding
i successfully coded the memory for ASS and eliminated OBD alarm and 3 legal disclaimers. All good now. Thanks to vkoprivica; your video was very helpful!
12-10-2017, 01:23 PM | #20 |
Rep 3
I don't see DME ecu in Esys for my 530i G30. Also it's missing in ISTA. That's strange.
Is there some trick for G30? Can someone save and share 530i's SVT? I want to try CAFD injection. |
12-10-2017, 01:26 PM | #21 |
2373
Rep 8,364
DME is engine ECU. You would have to have one present. You cannot use someone else's SVT.
12-10-2017, 01:33 PM | #22 |
Rep 3
There are 19 ECUs in Esys and ISTA. And there is no DME_BAC2 (and any DME at all).
I've tried to read data in diagnostic mode, with running engine, with just ignition on - same result - no DME. UPD: Screenshot attached |
