FS: Idatastart ADS-BM1 Remote Start Kit w/USB Loader & (2)Extended Range Remotes
10-19-2017, 08:40 AM | #1 |
32
Rep 141
*** Remote Start iDatastart ADS-BM1 Please read as this info is being updated often enough.... Just wondering if there is any interest in buying for the Idatastart ADS-BM1. It works on the following BMW and Mini models. Check the site out for more info. http://www.iDatalink.com It's a plug and play system. There are no wires that need to be cut for BMW. Uses existing BMW key fob. Whatever your current range is with your key fob will be your range for Remote start. If your can unlock your car while you are in your house, then you can remote start from your car from your house. Push lock Button 3x to operate. I have about 150ft on mine. It will also come with 2 Extended Range Remotes (up to 3000ft), one is a 2-way and the other is a 1-way, for those that do not have that luxury. Installation takes about 20min. AUTOMATIC TRANSMISSION ONLY. Does not work Manual Transmission. Sorry! So here are the details: Total Value price is $850. It includes everything you need to make it work. BM1 Remote Start USB Loader with credentials to access the website (Included. Normally $50) Installation video for the E90 series. (Available through web access) Detailed Installation instructions Tech support Shipping Currently there is total of about seven people. I have posted this group buy on two sites to reach the required minimum. E90post & Bimmerpost. Once there are total of minimum ten people ready to buy. Then I can email the seller the buyers contact info. At that point the seller would contact you directly. If you have any questions you consult the seller. Yes there may be cheaper alternative, but this is plug and play setup using your existing key fob, and you dont have to worry about any wire splicing (we all know that could be a nightmare waiting to happen). Let me know if you are interested or want more info. |
