BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Bad transfer case
      10-18-2017, 09:40 AM   #1
eltrapo67
eltrapo67's Avatar
Drives: 2006 bmw 325xi
2006 BMW 325xi  [0.00]
Bad transfer case
Looks like it spun the gears around and now there’s no teeth to move it.
      10-18-2017, 09:41 AM   #2
eltrapo67
eltrapo67's Avatar
Any advice would be appreciated
      10-19-2017, 06:26 PM   #3
jwebb335xi
Drives: 2008 335 XI
Yikes; sorry to see that! Good luck
Subscribed.
JWebb335xi
MHD / Wedge / 93 Octane/ xHP / FMIC / Inlets / Catted DPs / CP / DVs
      10-27-2017, 09:33 AM   #4
JETmn
Drives: 2011 335i xDrive Msport
2011 335Xi  [0.00]
What kind of advice are you looking for? Best bet at that point is to buy a used one in good shape and replace it.
2011 335Xi 6AT - VRSF catless DP - VRSF 7" FMIC with turbo inlet pipe - VRSF chargepipe - Pure Stage 1 turbo - JB4 - E30 - xHP Stage 3 - Strongflex tension bushings - Whiteline RSFB - UUC rear swaybar
      10-27-2017, 01:50 PM   #5
Shorts
Drives: E86 M coupe, E91 325xi
What symptoms did you have when driving?
      10-30-2017, 08:13 PM   #6
iwantaw335
22
Drives: 2015 320i
Sub
      10-30-2017, 10:14 PM   #7
p.s.
Drives: 2007 328xi
I'd prob awd delete. Actually starting to see these cars at junkyards might be able to grab another transfer case there.
      10-31-2017, 09:12 AM   #8
JETmn
2011 335Xi  [0.00]
car-part.com has them for $300 and up.
      10-31-2017, 03:25 PM   #9
ucdbiendog
91
Drives: 2008 335xi E90
this exact thing happened to me. a needle bearing in the clutch pack disintegrated, allowing the clutch to "over-compress" which in turn allows that gear to go too far. there are kits to rebuild the clutch, but i recall finding it was cheaper to just find a used one on ebay.
here's what happened to mine:
Appreciate 2
PhaseP1007.00
BKV12247.00
      10-31-2017, 10:04 PM   #10
domain007
21
Drives: 2010 335i X-drive
What were the symptoms you were having before it went kaput?
      11-01-2017, 10:01 AM   #11
ucdbiendog
91
kept getting the following fault:
- Fault: :Transfer case / Transmission ECU Failure / Clutch is in the open position - rear wheel drive - Transfer Ec / distributor gear fault
- Code: 005F3A
      11-01-2017, 01:30 PM   #12
ucdbiendog
91
here is what my crushed bearing looked like when i took apart the clutch pack
PhaseP1007.00
      11-02-2017, 08:37 AM   #13
JETmn
2011 335Xi  [0.00]
Wow, that is amazing! I should hopefully be ripping mine apart this weekend. Is that bearing inside the t-case?
      11-02-2017, 09:54 AM   #14
ucdbiendog
91
yes. here's a diagram: https://lh6.googleusercontent.com/-f...07/ATC-300.jpg
I believe it is contained within the #12 assembly. could also be #11. it it within the clutch stackup on that side
      11-02-2017, 11:48 AM   #15
JETmn
2011 335Xi  [0.00]
Got it, I knew I hadn't seen that on the diagram. My #43 is going out, just has some play so hopefully nothing else is in bad shape.
      11-08-2017, 05:36 PM   #16
ucdbiendog
91
did you ever get your t-case opened up?
      11-09-2017, 08:50 AM   #17
JETmn
2011 335Xi  [0.00]
Unfortunately some other things came up and I didn't get to work on it and I probably won't be this weekend either. I want to get it pulled and opened up so I can order parts, so maybe I can squeak it in some night.
      11-11-2017, 10:49 AM   #18
zmanfamily
Drives: 2008 335XI
Bearing noise in transfer case
I have a 2008 335xi and have a bearing noise that sounds like it is coming from the input bearing in the transfer case. Planning on taking it apart this weekend. I will post pics as I go.....
      12-29-2017, 11:01 AM   #19
RTH335xi
Drives: 2008 335xi
noisy case
i think i have a failing transfer case. any photos and hints you can post would be helpful. not sure i want to tackle this myself.
      12-31-2017, 09:40 PM   #20
Julian2485
110
Drives: Black lci e90 335 xdrive
- Code: 005F3A
Was there any grinding or any noise at all. I'm occasionally getting the 4x4 light but once i turn the car off and on it goes away. My alignment is way off though due to coilover installation and m3 rear control arms and heard real bad alignment can trigger it.
      01-04-2018, 05:56 PM   #21
jskin1510
28
Drives: 08 BMW 335xi
I'm wondering if this is what happened to mine (or maybe transfer case actuator? or is this the same thing)
A few months ago, as soon as the car started moving (or I went into gear) I got the lights and notifications on I-drive AWD, DSC, 4x4, Brake malfunction. Car has been only RWD ever since.
Wondering if this is the most likely option of what went wrong? or possible other options? Any other symptoms of what else was going on with yours before you confirmed it was this?
08 335xi- CP-E DCI's,VRSF 7" FMIC, UR Charge pipe w/ Tial Q BOV, JB4 G5, PE mod, 19" Sonic Tuning SC 7 wheels
      01-05-2018, 09:30 AM   #22
JETmn
2011 335Xi  [0.00]
I would try the worm gear first. Had the drivetrain been making grinding noises prior to that? Mine was getting pretty noisy and still hadn't thrown any codes.
