TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > do your koni yellows squeak?
      10-17-2017, 10:21 PM   #1
miker2013
65
Drives: 335xi 6mt Msport coupe
i am getting squeaking at all 4 corners on my konis
same squeak on all corners, sounds exactly like a rusty old spring mattress
i understood that the konis could sound swooshy or whatever but not like this
any thoughts?
shocks are set to full soft and are setup with stock xdrive springs
am happy with the performance (do have to add more damping but just wanted to see what full soft was like first) and find the shocks an amazing upgrade over stock but too noisy
also added subframe bushings and sway bars
the install was done 100% the car seems rock solid except for the squeak
the noise is most evident going slow over speeds bumps
thoughts?
      10-18-2017, 09:25 AM   #2
HawkeyeGeoff
HawkeyeGeoff's Avatar
Drives: E90 335XI MSport, S2000
any thoughts?
thoughts?
This tends to be the case usually only in cold temps; does it always happen or just in the cooler weather?
      10-18-2017, 10:09 AM   #3
miker2013
65
thanks
well it has dropped the temp here lately to 10-15 celcius
but it seems to do it regardless of the temps as it did it when it was warmer too
      10-18-2017, 06:44 PM   #4
kenmar
21
Drives: 335xi
Squeaking is usually poly sway bar bushings. One reason why a lot of people prefer the OEM M3 rear bar over aftermarket.
      10-18-2017, 10:43 PM   #5
miker2013
65
thx
i did replace the sways with uuc sways
they use poly urethane bushings do those squeek?
very noticeable in the front ill bet its them, at first it seemed fine but after a few weeks started squeeking like crazy
is there a non poly bushing i can use for the uuc bar?
      10-19-2017, 09:46 PM   #6
NiNeTyOne
Touring cars rock
Drives: e91 330xi / 997 GT3 Cup
thx
Grease the bushings properly and they won't squeak. You don't want to go to softer rubber bushings on the bar.
Make sure you torques all the mounting bolts down at ride height. Squeaking I have seen often comes from people who torqued everything with the suspension fully extended. Not only will it squeak, all the bushings will be torn up in no time.
Sportwagon Daily: I've done some stuff.
      10-20-2017, 12:09 AM   #7
miker2013
65
u can hear the sound at the end of this clip at 9 second mark and then again at 11 seconds
      10-20-2017, 12:29 PM   #8
miker2013
65
thanks
in theory tho, can i use the stock bushings on the uuc bars?
      10-20-2017, 03:47 PM   #9
TemjinX2
521
Drives: 2008 335xi e92
for my coil overs...i reused the oem rubber bump stops, that got rid of my squeky noise over bumps.
      10-20-2017, 05:19 PM   #10
NiNeTyOne
Touring cars rock
thanks
No you can't. The bars are completely different diameters. You HAVE to use the new ones or the bar will not engage properly.
      10-20-2017, 07:07 PM   #11
miker2013
65
does anyone have any thoughts on the vid i posted?
i have oem bump stops so its not them
i really hope the noise isn't the koni shocks
      10-20-2017, 07:19 PM   #12
TemjinX2
521
hmm...it could be the the sway bar bushings need to be greased like others have said. I would also check the top mount nuts on your front and rear shocks. Make sure there torqued to spec.
      10-23-2017, 03:19 PM   #13
p.s.
Drives: 2007 328xi
I have the exact same issue and was going to post a video of my own but it sounds so similar that I wont bother.
I'm fairly sure I found the issue as being the rubber of smaller control arm, the one in front of bigger one. I believe the technical term is front forward lower control arm.
I've come to this conclusion by disconnecting the sway bar from the sub frame and bouncing the car. After an eternity under and on top of the car I finally saw movement in the forward lower control arm rubber that seems to directly correspond with the creaking. I also had my struts done last year but the noise doesn't seem to be coming from them. I also loosened both the front and rear lower control arms with the car on ramps and re torqued which didn't change anything. I'm satisfied with my findings but I don't have a solution other than replacing the forward control arm which i probably won't do unless they are shot.
      10-24-2017, 05:55 PM   #14
p.s.
Drives: 2007 328xi
^^^^ NOPE I WAS WRONG ABOUT THE ABOVE^^^
I had more time today and its definitely coming from both tie rods. I put a stethoscope on them and jacked the car up and down. I can see the tie rods get stuck on something then pop down producing a creaking noise. Now to figure out why, hopefully its nothing expensive. Anyway thats my situation I don't have rear noise.
      10-25-2017, 07:45 PM   #15
miker2013
65
i am bringing mine in and i will update this thread
i had just replaced my shocks and springs and sways so i assumed it was to do with those but i will update once i know for sure
i thought my squeak was the sway bar bushing but could be the tie rods
ill let u know
      10-25-2017, 08:21 PM   #16
kenmar
21
Drives: 335xi
Tie rods that have a rubber boot puncture can dry out and start to "creak". Dry poly sway bar bushings sound more like a "squeak". That's the best description that I can think of.
      10-26-2017, 04:56 AM   #17
miker2013
65
thanks
mine is definitely a "squeak" and i did just add poly sway bushings a couple months ago so i think mine is the sways
