2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Whistling at 30mph in cold weather (228i)
      10-17-2017, 03:46 PM   #1
sandrik93
84
Drives: '23 M240i RWD
Hi,
I have a whistling noise in the car every time its at 30mph. then till 33~34mph it pitches up and then disappears. Only happens in cold weather so below 18C. Dealership service has no clue what it is. I still can't figure out where it's coming from. Blowoff valve changed, still the same, so not that. Doesn't matter if on or off throttle as long as the speed is at 30. Fairly loud usually. Sound like the wind noise when something's not sealed properly but can't figure out what it might be. Windows up/down, AC on/off doesn't change anything. Any ideas?
Edit: Got to record sound as well. Seems like it's coming from the front but can't be sure:https://vocaroo.com/i/s0IQA5z9QT5y
      10-26-2017, 08:39 PM   #2
Pat_335D
Pat_335D's Avatar
20
Drives: 2010 335D
Windshield
      10-27-2017, 02:06 AM   #3
gk09
gk09's Avatar
135
Drives: 1m
Originally Posted by sandrik93 View Post
Hi,
Do you have aftermarket mirror caps??? I hear these can produce a whistle
      12-29-2017, 07:17 AM   #4
Paisano
Paisano's Avatar
21
Drives: M4 Comp
Weather stripping on one of your doors. Your drivers or passengers side window might need adjustment, happened to me on my drivers side door.
      01-08-2018, 10:17 AM   #5
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
I just had a whistle sound this morning. It's was just as you described. It happened to be 22 degrees out as well. I popped the sunroof open and it stopped. I'm thinking that the seal gets deformed somehow when it gets that cold.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project
http://www.instagram.com/steve_inf31
      01-09-2018, 03:14 PM   #6
sandrik93
84
I thought mine was the sunroof at first but now sound comes with open, closed or vent positions. Since it's now cold every morning and I don't take highways to get to work, I have a pleasure of listening to that almost all the time.
      01-09-2018, 03:16 PM   #7
sandrik93
84
Would you be able to check if it's the window if you open one at a time? Did it do only when windows are up?
      01-10-2018, 01:08 PM   #8
Luv2
Luv2's Avatar
73
Drives: 2022 m240i, 2023 G87 M2
Do you have a sunroof? I had that whistling sound over 80 km/hr. Turns out I had some pine needles in the seal for the sun roof. I vacuumed around the seal and took it to a touch less carwash. Haven't had the whistle again...knock on wood
Love 911's
Previous cars: '99 GTi, '01 Subaru TS, '06 Subaru RS, '10 WRX, '11 WRX STi, 2016 m235i
      01-15-2018, 07:28 PM   #9
Paisano
Paisano's Avatar
21
Drives: M4 Comp
You could check the windows one at a time at high enough speed 100 km/h. Alternately shoot compressed air at the weather stripping and have someone sit inside to hear whistling.
I would measure the door window to B-Pillar gap. Since the car is a coupe and slamming the doors close over a longer period of time will shift the windows from their factory positions and might throw the window regulator off.
      01-16-2018, 10:46 AM   #10
shil
Huh? Wazzat?
shil's Avatar
32
Drives: 228i xDrive
When it's real cold out your window won't roll down the inch or so that it does when you open the door. When you close the door it doesn't seal properly and makes a racket.
Once the window thaws, roll it down an inch and up again.
      03-14-2018, 11:26 AM   #11
sandrik93
84
23 days at the dealership at they still couldn't do anything. DIY if you wanna do it well. @Luv2 I do have a sunroof. Cleaned it but nothing changed.
Windows are fine. I had windows open one at a time. Doors as well. As well as the sunroof. One of the rubber seals somewhere else must be messing up so I decided to put the masking tape all over and take it off one at a time to see which part does it. Hope it works. I'm out of other ideas..
      03-24-2018, 02:42 PM   #12
3rdcoast228i
225
Drives: 2016 228i Msport
Make sure your car has this part on both sides. Probably not it but worth looking into.
http://www..2addicts.com/forums/showthread.php?t=1200964
Tags
228i, noise, whistle, whistling noise
2addicts
