10-13-2017, 11:04 AM | #1 |
624
Rep 531
Alignment Necessary After Lowering?
Controversial subject incoming...
I recently installed the M Performance Coilovers. The sales guy at the performance shop suggested I get an alignment after the suspension has "settled" in "about a week." I know there's a lot of bro science online with car work just like anything else. But it's also been my understanding since I became a car enthusiast in my teens that any ride height change would warrant an alignment. Then I found this: https://blog.tirerack.com/blog/make-...lower-your-car
10-13-2017, 11:27 AM | #2 |
1773
Rep 4,510
Sales guy is wise - MP coilovers will settle and any change in F &/or R camber will effect toe-in of either axle....
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
CommitConfirm474.50 |
10-13-2017, 02:31 PM | #3 |
793
Rep 1,367
I don't know if there is any controversy...I don't know why someone would spend many dollar to modify a suspension and then not confirm that's it properly aligned and working correctly...seems like common sense to me
10-13-2017, 02:37 PM | #4 | |
624
Rep 531
My time is valuable. I'd rather not spend it doing things I don't have to do. Especially if I can confirm that with hard data. |
10-13-2017, 02:50 PM | #5 |
624
Rep 531
... also I think I might have misinterpreted that Tirerack Blog.
The author states an alignment kit is not necessary, which I'd guess probably means something that lets you adjust beyond the range of the existing hardware for correction. The implication is that a small drop of 1-1.5" can be corrected with the factory hardware. Something more severe might require modifying those parts - what might be more commonly known as a camber kit or something. I really don't know. Last edited by MineralGreyMetallic; 10-13-2017 at 02:58 PM.. |
10-13-2017, 06:17 PM | #6 |
475
Rep 549
Drives: The Bus
Garage List 2017 Ford Focus RS [0.00]
1971 Mk3 Austin Min ... [0.00] 2013 MINI R56 GP [0.00] 2013 MINI R55 Clubvan [0.00] |
In a word. Yes.
MineralGreyMetallic624.00 |
10-14-2017, 10:54 AM | #7 |
4176
Rep 3,073
Drives: 991.2 Porsche GT3, BMW E46 M3
Garage List 1987 BMW 325is [10.00]
2004 BMW X3 [6.50] 2018 Porsche 911 GT3 [10.00] 1974 BMW 2002tii [10.00] 2004 BMW M3 [10.00] |
This is a no brainer. YES, after changing anything regarding the suspension geometry of the car you should get an alignment to confirm everything is still in spec.
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii |
10-14-2017, 11:28 AM | #8 | |
2086
Rep 3,003
What Eibach is saying, is that lowering the car should not put the alignment so far out of spec that you would need an ?alignment? kit to bring it back into spec. Yes, you need to align the car and probably smart to check it again once the springs settle. |
10-14-2017, 12:59 PM | #11 |
475
Rep 549
Drives: The Bus
BMW state that any fine tread fixing be replaced once removed.
The 12 point 18mm shock strut to guide support (front & rear) nut is single use. The 5 hex head bolt that hold the guide support to the body are single use. They are stretched when the correct torque of applied and do not provide the correct clamping force if re-used The 16mm nut for both the front drop link to strut & front strut to hub carrier are also single use. The bolt that clamps the strut to the front hub carrier is also single use for the same reason above. The rear shock to lower arm nut and bolt are also single use for the same reasons. Now, flame suit on, a lot of guys will argue you can reuse them.... but if you go the dealer that will follow BMW guidance and replace these for a reason. |
10-14-2017, 11:11 PM | #12 | |
624
Rep 531
Ya, when I ordered the Coilover Kit I also ordered another kit that came with all that hardware. |
10-16-2017, 10:25 AM | #13 |
1324
Rep 2,924
I am getting new springs installed and I am doing the alignment the same day. Hope it helps your data base.
BMW ///M Club Montreal
BMW ///M Club Montreal Facebook Page |
11-01-2017, 06:06 PM | #14 | |
2017 M2, BSM, 6MT, Exec Package
142
Rep 103
I got my alignment done right after my MCS coilover's were installed.
12-31-2017, 11:34 PM | #16 |
123
Rep 88
Was it close enough to adjust using the OE hardware, or did you need to get additional adjustable hardware (like camber plates)?
01-01-2018, 10:17 AM | #17 |
52
Rep 88
Drives: 2008 335xi coupe
Don't forget to align the headlights too.
PPK | Mishimoto FMIC | ER CP | Forge DVs | RB Inlets | RB PCV | BMW PE | Dinan springs/Koni Yellows
