10-11-2017, 07:18 PM | #1 |
97
Rep 254
Drives: 2019 Black 330i xDrive
Clearing codes with ISTA??
Is it possible to just connect an F30 to ISTA via ENET cable and clear engine codes or reset service intervals or do you need to buy an ICOM scanner?
If possible, how can I go about doing it and resetting or changing service intervals?
2019 G20 Black 330i xDrive
10-12-2017, 05:49 AM | #2 |
451
Rep 1,201
ENet cable works fine. I've not done the service intervals but you can clear codes.
I would advise you go through the diagnostics though and not just blindly clear error codes. The software is very helpful there.
Current - 2021 G20 330i M Sport+
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d |
10-12-2017, 09:28 AM | #3 |
Coding ECU's remotely
445
Rep 1,176
Pretty sure you need a link to BMW AG in order to update the sevice history in ISTA+
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube |
10-12-2017, 11:40 AM | #5 |
97
Rep 254
Yeah it?s my rear brake pads. The pads are perfectly fine and don?t need to be replaced. I tried to reset it from the CBS. It says reset possible, but when I proceed the reset is always unsuccessful. I made sure that the hand break was disengaged and my foot was not even near the brake pedal. The only other recommendation I could find was replacing the sensor but the rear seems like you have to do an excessive amount of work to replace the sensor. I was hoping I could just just hook up with ISTA+ and reset the intervals from there too get rid of the service reminder.
10-13-2017, 04:51 PM | #6 |
97
Rep 254
Bump
10-13-2017, 11:06 PM | #7 |
97
Rep 254
Bump
02-18-2019, 02:57 AM | #8 |
1078
Rep 2,358
Hi. Can you give a short description on how you did the service interval in ISTA? I cannot find it.
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
