XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > X1 DIY (Do-It-Yourself) Discussions
      10-10-2017, 12:35 PM   #1
krossfyah
Drives: BMW X1 Asteria Blue
Programming - X1 2016
Anyone can recommend a good ODB reader/writer that works for the X1 2016 w/ software, I know there is Carly out there but you have to pay big money for the pro edition, I'm pretty certain there has to be others that are using something more relisitic with turning on/off some of the features on this vehicle.
      10-12-2017, 04:40 PM   #2
KWX1
KWX1's Avatar
25
Drives: X1 Xdrive35i
A good OBD to USB K/D can cable will run you $69 to $99.There are lots of junk cables out there for less. Then you will need to get the software. Try searching "MIke's Easy BMW Tools" , this is a free download and set up. You then will need to update the SPDATEN files to the latest edition(Ebay) . You should have a dedicated computer (no other programs) with firewalls off. You will not be able to use INPA to diagnose and clear codes with your model. You could use ISTA+ to diagnose, code, clear codes, flash. This uses a ICOM system to connect and will will cost you thousands. There are A few other programs out there. If you just want to Diagnose, clear codes, code and not flash. Buy a Carly. I have all three and the bluetooth Carly works great, is simple and has lots of options and keeps you from making dire mistakes that can brick your car. if you find Carly to $$ maybe you bought the wrong car.
      10-12-2017, 06:39 PM   #3
d1saster
Bulgaria
59
Drives: F15 N55 & E93 N51
The OP is asking about 2016 x1 which is F platform, uses Ethernet to obd adapter and esys software. The cheapest adapter is below $10. For software info look at the f30 coding forum.
      10-13-2017, 03:27 PM   #4
KWX1
KWX1's Avatar
25
The OP is in the wrong forum.
Search this Thread:
Advanced Search
xbimmers
