10-08-2017, 07:36 PM | #1 |
Noob
Rep 7
Issues after NBT HU retrofit
Hello,
I completed installation of a NBT HU unit that I got from eBay. Here are some issues I’m facing at the moment. I’m new to coding and wanted to see if anyone can assist with next steps. - Bluetooth microphone no longer working - Cannot set date and time - Being recognized as an X5 - GPS location not being captured (still waiting on the antenna) Would coding help solve some of these issues or am I facing bigger issues? Thanks in advance! —Chanrith |
10-08-2017, 09:59 PM | #2 | |
BimmerPost Supporting Vendor
665
Rep 1,976
Drives: 2020 G20 320i M Sport
As for not being able to set the time and date, that is because the NBT is coded for the expanded instrument cluster on the donor car and the head unit needs to be recoded for the base instrument panel. The vehicle graphic can also be changed via coding. If you need some additional help, feel free to PM me or email info@codemybimmer.ca
CMB Solutions Limited |codemybimmer.ca
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs Last edited by steve@codemybimmer; 10-08-2017 at 10:13 PM.. |
10-09-2017, 01:38 AM | #3 | |
Noob
Rep 7
Thanks so much for the much needed advice. I have a 2013 model 320i xDrive. The NBT HU is said to be from a 2015 328i but it's actually from an X5 according to the screen anyways. I'm guessing I will need the new mic cable but have no idea how that should be wired to the harness I have. I have the navigation bypass harness which I kind of want to do without if I can have the headunit coded properly. For the coding part I'm a bit uncomfortable with. I am a software engineer by day but things like this I may need to seek a professional. Though it would be nice to learn how to code the head unit myself in case I get curious and want to make future updates. --Chanrith |
10-09-2017, 03:33 AM | #4 | |
665
Rep 1,976
You shouldn't need a new mic cable if you have a 2013 unless your vehicle is equipped with SOS. Do you have the SOS button on the reading light? PM me with the last 7 digits of the VIN and I can check for you. |
10-09-2017, 03:20 PM | #5 |
Noob
Rep 7
It’s not equipped with the SOS button. Sending PM now. Thanks!
