10-02-2017, 02:48 AM | #1 |
21
Rep 72
Michelin alpin pa4 N-spec winter tires
On aware that when I ordered 540 xdrive with 20? rims the tires that came with this option where not all season tires. Only summer tires. I have after market rims and tires for the summer so I will be installing these winter Michelins on the factory rims for Wisconsin fall and winter months.
10-02-2017, 12:12 PM | #2 |
1566
Rep 29,202
Are the PA4 the same sizes as the OEM tires? Weird how the PA4 has a different tread pattern for the two sizes.
10-03-2017, 03:05 AM | #3 |
21
Rep 72
Yes same size 245/35/20 front 275/30/20 rear. I know I was thrown off as well with the different pattern but I ordered them as a set from tire rack.com and they said this is correct for the staggered fitment.
10-03-2017, 06:24 PM | #4 |
Rep 28
Have you had any previous experience with these tires (PA4's)? I'm currently exploring my options, and just wanted to know if they drive like a typical winter tire (mushy and noisy). Thanks.
10-04-2017, 04:20 AM | #5 | |
21
Rep 72
[QUOTE=Carbunkle22;22264477]
No experience. First time with these winter tires but I?m experienced when It comes to using Michelin tires. Very familiar with the brand. I figured I can?t go wrong. |
10-05-2017, 03:53 PM | #7 | |
Rep 28
I'm more concerned about the weather getting cold really, snow is rare around here, but it does get cold enough to warrant switching to proper tires. Having the Michelin PS4's (ultra performance summer) wouldn't be a good thing I guess. Last edited by Carbunkle22; 10-07-2017 at 09:53 AM.. |
10-05-2017, 04:39 PM | #8 |
85
Rep 375
I had the 20" 668M wheels put on before collecting my car and kept the factory 18" M wheels for winter use.
I am very happy with the Pilot Sport 4S and was planning to stick with Michelin and get Alpin PA4 for winter but apparently 18" 275/40 is not produced. I will probably run the 668M's also in winter as 20" Alpins are available in oem sizes. I love these wheels anyway and 18"s look too small for G30, i just dont like the idea of taking off and re-installing the tires a few times. Not good for the tires.
G30 540i xDrive M Sport MPPSK / BM3 |
10-06-2017, 11:02 AM | #9 | |
1566
Rep 29,202
10-06-2017, 11:38 AM | #10 | ||
85
Rep 375
10-06-2017, 11:46 AM | #11 | |
1566
Rep 29,202
I've got 245/40/19 all around on my 8.5/9x19 OEM 351M wheels.
emre85.00 |
10-06-2017, 12:06 PM | #12 |
85
Rep 375
Thank you for the photo @remmib , i appreciate that.
No, they do not look skinny at all. G30 is big though. I will either keep the 20" also for winter or go with 18" and square set up as you suggest. I've got plenty of time to decide, winter does not last long here. I will switch to winter tires mid of December and go back to summers beginning of March. I guess i can stand the 18" for less than 3 months
11-10-2017, 12:12 PM | #14 |
1566
Rep 29,202
Cool, how's the PA4 compared to driving on the summers?
11-11-2017, 06:04 AM | #15 |
21
Rep 72
Under non aggressive normal driving which is the only way I've driven the car so far to be honest it's hard to tell the difference. Normal winter tires make quiet a bit of noise but you can barely hear these tires. Don't know if it's the workmanship of how the car was engineered or the engineering of the tires. Maybe both.
11-12-2017, 04:55 PM | #16 | |
Rep 28
11-12-2017, 04:57 PM | #17 | |
Rep 28
11-15-2017, 09:23 AM | #18 | ||
21
Rep 72
11-18-2017, 01:51 AM | #19 | |
Rep 28
11-20-2017, 03:20 AM | #20 | ||
21
Rep 72
11-20-2017, 04:46 AM | #21 | |
1566
Rep 29,202
Winter Tyres http://g30.bimmerpost.com/forums/sho....php?t=1439847
Jay R21.00 |
11-24-2017, 04:08 AM | #22 | |
37
Rep 234
The 911 is much lighter on the front axle and this tire is rated 91 (615kg/1356lbs per wheel) for the load. All BMW winter tires for the G30 are rated 98 (750kg/1653lbs) or 100 (800kg/1764lbs) per wheel. Michelin offers the PA4 in 245/35/20 95W extra load. I would recommend you go with this one for your front tires. They have the same pattern as your rear tires. For info, summer tires (245/35/20 front) are rated 95 (690kg/1521lbs) or 98 (750kg/1653lbs).
2018 M550i Sepia-Violet
