335i - change spark plugs after 16000 miles
05-17-2008, 08:46 AM | #1 |
Moderator
270
Rep 4,481
Thus I wanted to check my spark plugs after 16000 miles ( all with PROcede V1, PROcede V2, JB2H and new AA Active Processor ) I bought a new set and exchanged them today.
What you need: Spark plug socket BMW 121220 ( Hazet ) Torque wrench 23 NM Hex wrench 5 mm 6 spark plugs BMW 12 12 0 034 087 Procedure: 1) Engine should be cold 2) Remove the microfilter 3) Remove the cowling 4) Remove the 4 hex screws of the engine cover 5) Remove the engine cover Now it looks like this ( you see the front part of the engine, cylinder 1-3 ): 6) Release the tab from the coil: 7) Unplug the coil: 8) Pull out the coil: 9) Remove the spark plug: 10) Install new spark plug ( 23 NM !!! ) 11) Re-insert coil and press it down 12) Reconnect the coil to it's plug ( tab is open ) 13) Close the tab 14) Press down the coil once again so that it does not stick out further than the others 15) Do this for every spark plug 16) Start the engine and make sure it runs smooth, turn it off again 17) Put on the engine cover 18) Put on the cowling 19) Put on the microfilter Done. |
05-17-2008, 09:39 AM | #2 |
Moderator
270
Rep 4,481
This is a brand-new spark plug:
After 16000 miles, all of them with piggyback tunings, using Shell V-power gas only ( 95.5 octane AKI = 100 octane RON ) my spark plugs look like this: No visible wear, color grey, spark plugs of cylinder 5 + 6 don't look different ( cylinder 1-6 from left to right ). IMO I changed too early, but this is good to know. Looks good to me. |
05-17-2008, 10:30 AM | #4 |
1979
Rep 1,847
Yeah your old spark plugs look good,I was gonna change mine too but they looked fine. I showed the #6 spark plug to one of the BMW tech here in town just to be on the safe side He also taught it'd be a waste of money to change em now.He told me to save em for 50kmiles.
Nice write up e.n335i! |
05-17-2008, 10:31 AM | #5 | |
175
Rep 1,517
Drives: E92 335i coupe Black AUTO
nice instruction.. dude they have 23MM torque wrench build in. just twisted them . listen for the click. there u go u are done.. lol |
05-17-2008, 10:48 AM | #7 | |
Moderator
270
Rep 4,481
Thanks, Eugen |
05-17-2008, 12:24 PM | #9 |
Moderator
132
Rep 6,775
Drives: TiAg E92 335
Excellent write-up Eugen! Thanks for taking the time to post this up.
Your plugs look perfect IMO. I use to change my plugs in my turbo s2k every 3,000 miles so I have seen quite a few plugs that were either too rich or too lean, but yours look fine.
-Michael.
Berlina Black S2000 CR is now in the garage l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l |
05-17-2008, 12:29 PM | #10 |
Modder Raider
753
Rep 8,633
Drives: M3
I just tried editing the master list and couldn't, so I contacted Jason.
This is a great DIY!
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
06-11-2008, 12:05 PM | #11 |
133
Rep 4,764
Forum Sponsor's (Tishcher BMW) special on the needed BMW socket and plugs for the N54 engine:
http://www.trademotion.com/partlocat...catalogid=4462 |
07-12-2008, 04:34 PM | #12 |
788
Rep 7,246
So theres no need to torque the spark plugs to a specific amount? Just tighten them in until you hear/feel a click?
LTMW Widebody+1M front bumper+Slek CF Lip|M3 Hood|StopTech BBK|M-Sport Rear Bumper+DD CF Diffuser|Custom Recaro Seats|KW V2|BavX LS3|M3 Side Skirts+Custom CF Lip|BBS CHR 19x10.5+BBS Lugs|LCI Taillights|RD Sport Anti-Sway Bars|GIAC S2|ER Intercooler+CF Shroud+Charge Pipe|Tial BOV|Injen Intake|MS downpipes|Custom Exhaust|BMS Oil Catch Can|M3 DCT wheel+TiD CF Paddles|BMW CF Trunk Spoiler|Aluminum Pedals |
07-13-2008, 12:06 AM | #13 |
127
Rep 1,048
Boost Nation: The socket from Tischer BMW does not have a built in torque setting, so you still need a torque wrench. There is a more expensive option available listed below that has a preset torque setting for spark plug changes (from Turner Motor Sports)
N52/N54 Spark Plug Torque Adpater Tool Part #: 83300491130 (83 30 0 491 130) Applications: 2006 - - (E90 E91 E92 E93 E60 E61 X3 X5 Z4) This Genuine BMW tool is purpose built for torquing the spark plugs on the N52 and N54 engine to precisely the right torque spec. This ensures you will not over or under tighten the spark plugs on the E90/E92 3 series or 2006+ E60 5 series 6 cylinder engine. This adapter has standard 3/8" drive receivers on it, so you can use it in line with the BMW spark plug socket (part# 83300495560) and tighten until you hear the "click", which lets you know you have applied just the right amount of torque (23nm). Price: $139.00 |
07-13-2008, 01:52 AM | #14 | |
175
Rep 1,517
there is a bmw tool have already build torque setting for tighen the spark plug. I believe this is bmw oem special tools 12 1 172 |
07-16-2008, 02:26 AM | #15 |
304
Rep 1,928
Drives: had e90, 330i mystic blue
I ask my dealer and they told me that they will change the sparks plug at 60k miles ( I have 46k I think that's crazy I going to order the set and change them
E90 Mytic Blue 330i 07-20-2006. 05-17-2011
Doesn't the idea of making nature against the law seem to you a bit . . . unnatural? Support NORML |
07-19-2008, 05:36 PM | #16 |
788
Rep 7,246
Instead of spending $140 on a tool that will toque itself, I'll just spend $10 on a normal torque wrench and just set it to 17 lb ft of torque, which is the equivalent of 23 newton meters.
07-23-2008, 03:18 PM | #17 | |
111
Rep 1,772
For me, I will rely on my Snap-On torque wrench for this. Although I am looking at another 100K km before I touch the plugs on my car since I have an N52 with no aftermarket tuning. |
09-03-2008, 10:17 AM | #18 | |
548
Rep 6,563
What engine N52 or N54 do I have if I have an 2006 e90 330i? I can believe I have over 60K miles and i don't even know what engine I have
under construction! |
01-30-2009, 09:44 PM | #20 |
219
Rep 8,375
Drives: Just a car
I need to change my spark plug and I don't wanna take my mods out so I took it to a shop where they have fix many BMW's and also building a E90 race car. Anyway long story short, he broke 2 coils while try to pull them out. luckly close by dealership had few coil in stock and was able to do it under warranty. So I will be more careful when you DIY this. Make sure you call your dealer and make sure they have coils in stock or else you gonna stuck when you have one or more coil break on you. Here is the picture where it broke. When we picked up the coil from the dealership, one of the tech mentioned this is a common breakage for them as well. Good luck!!
03-25-2009, 05:31 PM | #21 |
164
Rep 2,875
When taking out the plugs, do you unscrew them? Or just pull them out?
I got to the spark plugs then realized that my extension adapter wasn't long enough to reach the plug, it is deeper than I thought......... Thanks, P.S. NM, I think we unscrew them to take them out or else we wouldn't need to torque them when installing them.......
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
03-25-2009, 05:33 PM | #22 |
72
Rep 613
you need a longer extension then. you must unscrew them. no way around that.
